1994 rt 10 ..wont start after i just turned it off :(
Discussion in 'New Owner Questions' started by brukowski85, Sep 1, 2012.
  1. brukowski85
    brukowski85 Viper Owner
    32
    51
    Feb 21, 2011
    long island, ny
    Hey guys can someone help me i took it out for a lil bit..i turned it off now it wont start back up...any advice?
  2. Rapid1
    Rapid1 Viper Owner
    57
    Jun 1, 2011
    Plymouth MA
    What are the symptoms? Completely dead. Start for a second with security lights blinking?
  3. brukowski85
    32
    51
    Feb 21, 2011
    long island, ny
    No security everything works..lights radio ..i just finished driveing it now wont turn back on..i turn the key and nothing happens
  4. 99 R/T 10
    99 R/T 10 Enthusiast
    10,315
    Jun 4, 2001
    Enterprise, AL USA
    Clutch safety switch. Common for it to wear and make it difficult to start. Push the clutch in HARD and slightly to the right or left.
  5. brukowski85
    32
    51
    Feb 21, 2011
    long island, ny
    Just tried that maybe i dont have the magical touch..imma keep trying that
  6. propsail
    propsail Viper Owner
    879
    Sep 3, 2004
    Connecticut USA
    Try pulling the floor mat back a little. Sometimes that interferes with the switch
  7. brukowski85
    32
    51
    Feb 21, 2011
    long island, ny
    Nothings working :(
  8. Tom Sessions
    Tom Sessions Enthusiast
    48
    808
    Oct 3, 2000
    Hampstead,NC.
    Sent you a P M
  9. herbbone
    herbbone Viper Owner
    104
    May 20, 2012
    Moscow. Pa.
    Really MASH the clutch pedal. My 96 has done this before. If the clutch pedal has L/R movement the lexen bushings need to be replaced. A very cheap fix, but a pain to do for the first time.
  10. herbbone
    104
    May 20, 2012
    Moscow. Pa.
    PM sent.
    Mark
  11. VYPR BYT 94
    VYPR BYT 94 Viper Owner
    2,458
    Mar 20, 2011
    Green, OH
    All good advice so far but if Tom sent you a pm, then he'll get it figured... he's the man!
    If you do try it though, mash it to the floor and keep the pressure on it while moving your knee left-to-right. That will give it a different angle of trajectory allowing a different movement... push from the left - push from the right.
    I can't believe those bushings went that much that fast. Should be some gradual warning I'd think.
    Maybe it's something else like the in the switch.
    Mike
  12. 99 R/T 10
    10,315
    Jun 4, 2001
    Enterprise, AL USA
    Did you get it fixed? If so, what was the problem?
  13. brukowski85
    32
    51
    Feb 21, 2011
    long island, ny
    Didn't get fixed yet ..I had no time to work on it and try to bypass the switch
  14. 99 R/T 10
    10,315
    Jun 4, 2001
    Enterprise, AL USA
    It should be one of three things, the ignition switch, clutch safety switch or the solenoid/starter. Try to turn the key with a volt meter on the clutch safety switch. If it shows power when the key is placed to start, ignition switch is eliminated. Then put the volt meter on the solenoid/starter and see if there is any power with the key turned to the start position. Go from there. Curious to see if it might be the ignition switch.
  15. brukowski85
    32
    51
    Feb 21, 2011
    long island, ny
    I'll post when I figure it out..I'm going to have time wednesday to take a look at it
  16. brukowski85
    32
    51
    Feb 21, 2011
    long island, ny
    hey guys ended up being the starter cars back up and running again
Share This Page
