2003 versus 2004
Discussion in 'SRT10 and SRT10 Coupe Discussions' started by DIESELDOG, Apr 2, 2018.
  1. DIESELDOG
    DIESELDOG Enthusiast
    41
    Mar 22, 2012
    Can anyone tell me the difference (if any) between a 2003 and 2004 SRT-10?
    Thank you
  2. Steve-Indy
    Steve-Indy VCA Venom Member - Great Lakes
    7,955
    The difference that I worry about has to do with the change made to the harmonic damper bolt. In 2004, they used a long, skinny bolt (110 mm X 14 mm) torqued to 130 ft-lbs. Prior years and subsequent years used the 2.25"x0.75" bolt torqued to 250 ft-lbs.
    Sadly, some 2004's developed serious issues early on.
  3. DIESELDOG
    41
    Mar 22, 2012
    Thank you for the information
    Diesel dog
  4. Steve-Indy
    7,955
    One should check the crank damper bolt on all Vipers periodically as they can loosen. With 2004's, the "fix" was to clean, then LockTite the bolt, that torqueing it to 160 ft-lbs.
    I know/have know many 2004 owners who had no problem whatsoever after this issue was addressed.
  5. Steve-Indy
    7,955
    The power steering fluid became Mopar ATF+4 in 2004 to present.
    Also, the brake calipers moved from black in 03 to red in 04.
    The "boot cover" came standard starting in 04...AND the White Mamba & Black Mamba models were introduced.
  6. Steve-Indy
    7,955
    DIESELDOG, are you looking to get back in a Viper?
  7. DIESELDOG
    41
    Mar 22, 2012
    Steve-Indy, I looked at a 2003, and decided on a 2004. Purchased this morning.
    Thanks for you notes on 2004.....most helpful
  8. Steve-Indy
    7,955
    Congrats, Sir !!
    By the way, if my guess is correct, we are about the same age...and, we both thoroughly enjoy Vipers. Rock on !!!
  9. DIESELDOG
    41
    Mar 22, 2012
    Steve-Indy, I am 77 and have owned new 94, new 03, and a used 08. I just purchased a 2004.....probably will be last. My first car was in 1961 (MG twin cam), and I've always been a car nut. Tried them all (Diablos, Ford GT, Z06, Toyata 2000 GT, ) I put 93,000 miles on a Ferrari 308 GTB in 1978-1983. Enough....could go on and on. I still prefer Viper when compare to all new everything automatic.
    ViperJeff likes this.
  10. Steve-Indy
    7,955
    Agree !!
  11. wreckless
    wreckless Viper Owner
    35
    Apr 29, 2005
    Southwest Florida & South Jersey
    Be careful changing oil on a 2003. Early cars used the previous model's oil pan and the volume was less. You will overfill it if you use the posted 2003 specs.
Share This Page
