Ad placed for Hoosier A6 tires
B
Boxer12
Colorado High Country
Sorry typo..315s for front. About 6 heat cycles and lots of rubber left. Scrubs denote 'well worn' tires. These never raced, I just used for TT.
Allan
La Junta Colorado 81050
I have my own tire shop, It just seems that 315 should be on an 11" wheel. I am running stock 6-spokes. 295 is as wide as I think I want to get on the 10" wheel.:rolleyes:
B
Boxer12
Hoosier recommends 11" wheel for the 315. You do a lot of track days..suggest you get some good track wheeels ...11 and 13's
Allan
Are you running aftermarket 11" wheels? -Or are you cramming the 315's on the ACR wheels? I do not like the look of aftermarket wheels on cars like Vipers or Corvettes and similar cars. I think most of the OEM wheels look more appropriate for each respective car.
wing
Viperless loaned me a set of 315s after I corded my 295s. I thought they worked better that day then the 295s. He then told me about a site that sells them used. I ordered a set and have done a couple of track days on them with more left in them. The condition of the used tires was better then advertised and you could not beat the price. I also thought the wear pattern was better with 315s then the 295s. I will continue to use them on my ACR. Now just looking for a deal on a set of ACR rims and used 345 R6s.
Viperless
MN
I do as well. I have no problem mounting the 315 on a 10" wheel. Sidewalls bulge a little but I only run them on the track. I'd stick with a 295 on the street.
I'll post a pick of a 315 mounted on a 6-spoke if you like.
Viperless
MN
That almost looks normal. I can't believe it. :omg:
You really have to see it in person. There's a slight bulge to the sidewall. Doesn't look bad but it's noticeable. Pics can't show how it really looks.
kmagnuss
