aftermarket muffler hanger problem on 05 viper
agdetail
vancouver, bc
purchased a used muffler. was told it was bought from hennessey but says magnaflow on it.
when doing a test fit i found that the muffler has 2 hangers opposed to the stock muffler that has 1.
also the stock muffler hanger has a wider in diameter hanger.
is there a adapter i can install to accept the 2 hangers?
this is a picture of the exhaust. look at the end near the tip. it has 2 hangers welded on it.
http://ep.yimg.com/ca/I/yhst-54734705425182_2213_69576645
345s-bspinnin
Houston, TX
Your factory setup had four hangers, two front and two rears. The fronts have two holes, while the rears have a single hole. When using an after market exhaust, typically only two hangers are used. Most will require that the front "two hole" hanger be used in the rear.
345s-bspinnin
Houston, TX
Our site sponsors could probably get these for you easily. I would think you could get them new from Woodhouse (Mark Jorgensen), or used from Don Scharf.
No members online now.
Dsalameh
