Autometer gauge set up questions?
jsarker
Michigan
That does look like a really odd problem. You may have better luck posting this to an AEM specific message board: http://forum.aempower.com/forum/index.php/board,75.0.html
That said, there isn't any setup/calibration necessary with the AEM. It could be an issue with the wiring though; what do you have as the power source for the gauge/sensor? And are you sure everything is grounded well? That may be a good starting point before you start calling AEM for a possible replacement.
For a point of data, I am also running the UEGO. I sourced the power off of the cigarette lighter and grounded it at the same point that the stock gauges are grounded on my '05.
Good luck.
-Jon
Lennatave
