battery or alternator problem?
Ratical2
San Jose, CA
You can buy a simple Battery/Alternator Tester that plugs into your cigarette lighter and will tell you the condition of you battery and if the alternator and rectifier are working properly. It is only a quick check and can point you in the right direction.
Testing a battery without a load doesn't tell you the condition of the battery.
Here is another way to check if the charging circuit is working properly.
http://www.aa1car.com/library/charging_checks.htm
jwolf
Vincennes IN
I guess first thing I would do with any electric problem is replace battery, hell today it's less than the cost of the tank of fuel.
AZTVR
Chandler AZ
OK, I know that this input is very left fieldish. Why did you replace the oil lines? My '02 oil cooler lines have braided steel coverings; does an '05? IF your engine ground strap is missing or bad connection, then your oil lines could have been providing at least some of your ground return current path for the starter. Then, the oil lines may have failed because they couldn't handle the current. Then, you can't start the car because the intended "secondary" ground was bad to start with and your unintended ground has also failed. Now, you fix the unintentional ground path (oil cooler lines) and you are back to where you still have the original defect but won't see it cause a problem until the alternate ground path fails again.
Implausible? Probably; but, I have heard that scenario mentioned somewhere.
A
agdetail
vancouver, bc
battery replaced with interstate
oil lines change because of leak (original only have metal fittings. rest is plastic )
engine ground is there (from engine to frame) does not look corroded
will check with volt meter this weekend when i get the car back on jacks
bluesrt
bench tests will fool you,you have direct power to the starter, a bad starter can work when bench testing-bench testing anything is a no no in my book, i never do it,it will bite you in the ass
A
agdetail
vancouver, bc
im going to double check my ground first.
is there any important ones to check other than the engine to frame?
i plan to add another one from engine to top of towers.
slitherv10
I had that problem on my Vette( excuse the word here), I would put a new battery in it, changed the alernator and after sitting for a few days it would lose voltage and hard starting again. I found the problem was an old alarm system relay that had a short in it. I removed the relay and the car stayed healthy after that. No drainage anymore on the battery.
You might have a short somewhere.
you said the battery read 14.8 on start up and 13 volts when shut down. That seems alittle high in voltage during those times. High voltage means resistance which means a short.
My .02 cents canadian which would be equal value to you as you are canadian right?
A
agdetail
vancouver, bc
thats is what im thinking. might have to start removing fuses to find out which is shorting it out.
my speakers have a popping sound from time to time and even after turning off the car it continues to emit a popping sound.
A
agdetail
vancouver, bc
Darn thing did it again. Went to fill up on gas and would not start. But started before I left the house and it's been a week since I drove the car.
Also I did a rad flush and had to start the car 4 times after it cooled Down and started no prb.
Before I rush to spend my money on a new starter. I want to check out the wiring and replace those.
Does anyone know where the ignition is and the starter location is on a 05? I think. It might be the starter solenoid
A
agdetail
vancouver, bc
i think i solved the problem once and for all.
it was the ground cable from engine to frame. the engine side was loose so im guessing it did not have a good enough contact.
went and replaced it with a 2gauge wire and also replaced the battery with a 0 guage.
started it up fine after going to get gas, eat, and movie today. also when starting the car. the volt would drop from 12.7 to 9.9. is this acceptable?
and the battery read 14.2 at idle
with the new thicker ground wire, the engine side still wiggles a bit. and the bolt is tight. will a battery felt washer work?
A
agdetail
vancouver, bc
brought my car into tech shop. they load tested the alt and battery and both are great.
the starter on the other hand tipped the 500amp when cranking. they said could be 600 or more.
how much is it suppose to use? rebuild able?
viperscott
I had the same problem with speakers popping, and dead car after 2-3 days of sitting in garage.
Probably it is not main reason with your car (fixed engine ground sounds way better), but you should check it also, so you will not be negatively surprised in the future. Nothing worse than wanting to drive and car not even cranking...
with me - result was - every 2-3 days fault amplifier (under pass. seat in gen3) drained my battery completely. CHeck battery drainage when car is turned off and compare it to meter readings when stereo fuse is out. If it is difference - something is going on there, too.
Scott
Lennatave
