<FONT size="4">Save on select items from now until October 31, 2000
While supplies last!
Viper Engine Calibrator (VEC1), for all GTS Models, 1997 & newer RT/10's
Buy one, save 10%, buy two or more, save 15%!
The stock Powertrain Contol Module on the Viper provides too little fuel and excessive advance at part throttle loads. Conversely, the PCM provides too much fuel and too little advance at Wide Open Throttle. Our VEC1 allows you access to the untapped power within your engine by giving you the ability to adjust fuel and timing curves for different load conditions or engine modifications. Noticeable gains in throttle response and top end power are literally " within reach". The VEC comes with a high quality LED Air/Fuel ratio gauge, that cleanly mounts to the top of the steering column so that you may monitor your engine's performance. The control box is mounted inside your car. All components for installation and tuning instructions are included. No drilling or special tools required! Compatible with all PCM's, though the largest gains in power and throttle response will be when used with a stock PCM. Most Vipers pickup a peak of 14 HP and 16 Ft. Lbs of torque at the rear wheels across the entire RPM range. 6 month warranty. Includes a 30 day money back satisfaction guarantee.
Regularly priced at $495.00 Plus S&H.
Buy one during this sale for $445.50 and save $49.50!
Buy two or more during this sale and save $74.25 each!
Borla Cat back Exhaust Systems
We have Borla Cat-back Viper exhaust systems in stock. These are stainless steel from front to back and carry Borla's million-mile warranty. For rear exhaust cars.
Regularly priced at $1099.00 plus S&H.
On sale for $1049.00, save $50.00!
Dodge Viper Pedal Modification Kit
The Viper pedal kit consists of a replacement clutch link that improves the clutch motion ratio, resulting in shorter pedal throw and faster clutch actuation. The clutch pedal is also lowered by approximately 1" so that it matches the height of the brake pedal. Includes illustrated instructions and installs in minutes! No special tools required. Also included are detailed instructions on how to achieve full throttle and adjust the location of the gas pedal to help make heel and toe downshifting easier. For Vipers with adjustable pedal assemblies. Lifetime warranty. 30-day money back satisfaction guarantee.
Regularly priced at $24.95 Plus S&H.
On sale for $19.95!
Radiator Fan Control Kit
20% off!
When you shut your Viper's engine off, the radiator fan stops running, no matter how hot the engine may be. Our kit automatically combats heat soak by cycling the radiator fan on as needed. A natural flow is created when the cooler water in the radiator sinks and is replaced by hot water through the upper radiator hose. All components needed for installation are included. Installation is easy! Done with simple hand tools in less than 25 minutes! No cutting, drilling or soldering required. All high quality components including fused relay and stainless steel sealed temperature sensor. Helps protect your investment! 30 day money back satisfaction guarantee. 6-month warranty.
Regularly priced at $99.95. Plus S&H
On sale for $79.96!
You must mention this ad to take advantage of these special savings.
To order any of the items:
Call, email or fax your request to us. Please include part description, your name, phone #, shipping address, shipping method preferred and payment method preferred. We accept Master Card and Visa
Send your order to:
Roe Racing
(904) 733-5469 voice, 733-5479 fax or e-mail at [email protected]
Visit our Catalog at http://www.roeracingonline.com/portfolio.html </FONT s>
On sale for $19.95!
20% off!
On sale for $79.96!
Send your order to:
Roe Racing
