Brakes and rotors 2001 viper
Discussion in 'RT/10 and GTS Discussions' started by alexander m embry, Oct 16, 2009.
  1. alexander m embry
    alexander m embry Enthusiast
    Oct 4, 2009
    Trying to change brakes and rotors on 2001 viper with ABS. Cant seem to get the calipers and rotors apart on the driver rear side due to the rotors having a lip on the outer edge and not being able to spread the calipers apart. The e brake works together with the car brakes so the brake piston has to be rotated as you push it back in. Unlike the pre 2001 vipers I'm unable to take the pads out with the rotor in place there is no pin. Anybody know how?
    Alex.
  2. AZTVR
    AZTVR Enthusiast
    2,990
    Aug 28, 2005
    Chandler AZ
    I assume that you solved this particular issue? I just saw your post on the squeaky brake thread that you had removed and reinstalled successfully but with new problems.
    I suggest that you should start posting your mechanical questions in the regular gen I/II forum where you probably will get more answers. They don't sound like newbie questions to me; so, it seems appropriate for that location to me.
  3. alexander m embry
    Oct 4, 2009
    Thanks Jim for the advice. Haven't had a chance to reattempt. I've been busy fixing the car door handle wiring.
  4. RTTTTed
    RTTTTed Viper Owner
    6,438
    Jun 6, 2007
    There are two bolts holding the caliper to the spindle.
  5. mjorgensen Woodhouse
    mjorgensen Woodhouse VCA Member - West
    4,969
    Jun 8, 2005
    Omaha NE.
    If you are replacing the rotors and pads just file or grind down the edge and slip the calipers off.
  6. alexander m embry
    Oct 4, 2009
    I thought the thats what had to be done..grind down the edge; infact, I bought a metel grinding disk for my angle grinder 2 days ago..thanks for the info.
  7. GBS
    GBS Viper Owner
    637
    Dec 19, 2007
    South Florida
    I pulled my rotors off my 2002 ACR last week. Even though the my rotors had a lip on them I didn't have any problem getting the calipers off. I did have to really beat the rotors with a rubber mallet to get them to brake loose. You should be able to get the calipers off without griding down the lip. Are you sure you don't have the emergency brake on?
  8. alexander m embry
    Oct 4, 2009
    Yes, I'm sure the e-brake was off. I also got the rotor off with the mallet beatings but it seemed to abusive.
  9. RTTTTed
    RTTTTed Viper Owner
    6,438
    Jun 6, 2007
    Hopefully, you're changing the brake pads? Beating on the rotor or caliper could break the bonding bewteen the pad material and the steel backing plate. I'd recommend replacing them to be safe.
    I didn't beat mine to get them off, but they fell apart when I did get everything apart.
    Ted
  10. alexander m embry
    Oct 4, 2009
    I did have some chips on the brake pads when i use the mallet and i was planning on changing out the pads and rotors.
    Thank you all for your input.
Share This Page
