PRS Inc
In response to a number of requests for Comp Coupe connectors:
The mating connector to the following Comp Coupe electrical connectors:
Aux Power points;
Radio power output;
Trans and Diff Pumps;
is the Weatherpack 2 Way connector (male housing female pins).
This connector is available from most NAPA Auto part stores, and we at Precision Race Services carry it. The connector uses a fold-over terminal with a weather seal. The terminal can be crimped with most fold-over pliers. A touch of solder can help make the termination better, but isn't required.
Here are the PRS part numbers if you need to order it from us:
1) Mate to connectors on the Comp Coup Harnesses:
PRS #10101B Male Housing, female terminal Cost $1.25 each
(includes housing,terminals,and weather seal)
2) Connector on the Comp Coupe Harnesses:
PRS #10101A Female Housing, male terminal Cost $1.25 each
3) Complete mating set:
PRS #10101AB Both Housings, terminals and seals Cost: $2.50/set
4) Weatherpack crimper:
PRS #5013 Cost: $65.00
Contact: Clint at Precision Race Services, Inc. (248) 844-1060 if you need to order. or email [email protected]
If you have any questions you can address them here at this post or the above email.
Jim Kelly
Aux Power points;
Radio power output;
Jim Kelly
