Gear Ratio - 2000 GTS w/Gen V Wheels
ViperRyan00
I know these came stock with 3.07, I have 19's on the rear, so this would bring my gear ratio down to 2.97 range, or so I have read.
My question is, what are the gears/brand you would recommend? Unitrax seems like the ones to go with, ratio's 3.55/3.73/3.91?
Curious as to what you guys are running and your opinions on the set up.
Thanks in advance.
steve e
It kind of depends on whats done to the car, and what size tire you are going to run to find your final diameter, not just the rim size. If the car just has some bolt ons and run a stock size tire on the 19 rim, I think you would like 3:55, great all around gear. Thats what I am running on my 99. And I have tried them all.:usa:
Cannibal
I replaced my stock gears (Gen 2 modified) with 3.55's. Great improvement and easier on the clutch discs.
