Go To This Website.....and then!
Discussion in 'Sneaky Pete's Place' started by qburge, May 16, 2005.
  1. qburge
    qburge Enthusiast
    221
    Jul 7, 2002
    Little Rock, Arkansas
    Go to this website and look down on the left side where
    it says "For Your Viewing Pleasure" and select "220 Motorcycle"
    to see one hair raising video! The front wheel doesn't touch
    down until the speedo crosses 140 mph!
    http://www.texasdrivermagazine.com/
  2. Vic
    Vic Enthusiast
    6,757
    Nov 12, 2000
    Thats fake, here's why-
    When you are going 220, those white lines in the center of the road won't look distinct, they would be a blur. Not sure about the length and spacing of the stripes? Fine, watch it again, and take notice of the first side road that comes up on the left, it shows up at about 38 seconds into the vid. Its only a narrow two-lane side road, and it goes by VERY slowly. Looks like maybe 100mph, if that. If you were going 220, that side road wouldn't even register so much as a blip on the vid. As it is, it goes by so slow that you can see the white stripe limit line covers only one lane, for the traffic that is heading towards the main road. At the very end of the vid, that last shown speed is 100 mph. At that point, by the scenery going by, it looks like the speed is closer to about 55!
    But thanks for the vid just the same! :)
  3. Viperfreak2
    Viperfreak2 Viper Owner
    2,548
    Feb 14, 2002
    Duncan, SC USA
    Video has a way of hiding speed. It always looks slower than it really is. Kinda like watching a jet land. There's no reason to fake a video like this. The key is the tach, it keeps going after the speedo is at its limit....
  4. gthomas
    gthomas Enthusiast
    1,201
    May 21, 2003
    Peoples Democratic Republic of New Jersey
    +1
    And time. If you go by the time on the tape, it's about right for the bike.
  5. qburge
    qburge Enthusiast
    221
    Jul 7, 2002
    So is this fake or not?
  6. Fast Freddy
    Fast Freddy Viper Owner
    1,312
    Dec 7, 2001
    TUCSON, AZ - USA
    the vid is real. look closely at the guages (tach and speedo) and you will see the reflection of the riders helmet and upper body in them. when he drops the bike down from the wheelie at 140 mph you see his upper body and helmet move forward on the bike closer to the guages. he has now moved into a tuck position for aerodynamics. he stays in the tuck all the way up to his top speed of 220 mph and then once he has slowed back down to 150 mph you see that he raises his body and head back upright out of the tuck. this vid is real. i own and ride a turbo bike and i own and ride a nitrous bike.
    thanx for sharing the vid. its one of my all time speed flix :headbang:
  7. Fast Freddy
    1,312
    Dec 7, 2001
    TUCSON, AZ - USA
    he does a wheelie at 50 mph and rides the wheelie all the way to 140 mph shifting 3 times while wheeling and on the shift to 4th gear at 140 mph the front of the bike finally falls back to earth at which time he goes into a tuck. reminds me of the way i ride my turbo bike only mine is alot slower than a 1300 cc turbo busa runnin way more boost than me. my turbo kawi only has 1052 cc's and i am only runnin 8 psi of boost. but i still have managed a 3rd gear power wheelie (all throttle-no clutch) at 100+ mph :D
  8. Vic
    Vic Enthusiast
    6,757
    Nov 12, 2000
    Hmmmm.....
  9. ViperJohn
    ViperJohn VCA Member - Northeast
    3,603
    May 29, 2003
    Maryland
    The guy changed the sprocket on his bike and didn't calibrate the speedometer. He was going fast, but not 220 mph.
  10. Photo pro
    Photo pro Viper Owner
    207
    Nov 5, 2003
    Ringgold Georgia
    I agree, when he slows down to 100 it looks like he is barely moving. Something isn't right here!
  11. Bonkers
    Bonkers VCA Member - Northeast
    4,884
    Feb 26, 2002
    DelaWhere? USA
    Fake. I've seen onboard NASCAR videos that look downright blistering compared to this one and we all know those guys aren't very fast...
  12. Chuck 98 RT/10
    Chuck 98 RT/10 Enthusiast
    17,930
    Oct 15, 2000
    tampa, fl USA
    There's no way that looks like 220mph.
  13. Fast Freddy
    1,312
    Dec 7, 2001
    TUCSON, AZ - USA
    motorcycle speedos are notoriusly inaccurate. i have owned 4 steet bikes and all 4 of the speedos said i was going faster than i really was. how do i know this? because i own a gps and i strapped it to the bikes to find out just how optimistic they were. some bikes are worse than others. it doesn't matter if it is a old skool analogue guage or the newer sport bike digital guages, they all read wrong. the worst part about it is > is that your odometer is off now as a result of your speedo being wrong. your odometer will say that you have ridden your bike more miles than you actually have.........sux 4 resale value.
    changing sprockets (gearing) will obviously make the speed more inaccurate or more accurate depending on wether you gear the bike up or down. for instance if you gear the bike down this will make the speedo reading of innaccuracy even worse. most stock bikes gear down. when you gear up the bikes speedo will read more accurate. most major modified bikes like turbos, nitrous, etc gear up.
    when my honda cbr-929 was stock my speedo was innacurate. at 165 mph on my gps my bikes speedo was reading 175 mph. i regeared the bike up 3 teeth in the rear (went form a 43 to a 40) to take advantage of a 40 hp shot of nitrous that i sprayed in 6th gear. at 175 mph on my gps my speedo was now reading 175 mph. so as you can see by gearing the bike up my speedo now became accurate.
    that being the case the owner and rider of the turbo busa you see in this vid more than likely regeared his bike like i did mine, to take advantage of the tremendous amount of power that a bike like this makes. i bet that his speedometer was more than likely accurate as a result. i have seen a picture of a gps with a tattle tale strapped to the triple tree on the bike you see in this vid and the gps said 232 mph :eek:
  14. RockStar
    RockStar Enthusiast
    179
    Oct 3, 2000
    Fort Erie, Ontario, Canada
    Thanks again for bringing so much class to the table Freddy.
    I bet you've never even pissed in the shower.
    PS: For what it's worth, I've seen this video before, and I think it's real.
  15. ViperBite
    ViperBite Viper Owner
    483
    Jan 21, 2005
    Orchard Park NY
    Using the white strips as reference and remembering my in car video of the SilverState races I have, I can't believe 220mph. I can believe 160 plus top speed but this video just does not seem right. I would guess the bike was re-geared for faster acceleration rather than top speed.
    If true, that is one fast bike to 220 plus.
  16. Ulysses
    Ulysses Enthusiast
    3,410
    San Diego, CA. USA
    220MPH ~= 322.67 Ft/sec.
    Judging from the size of the bike, at the beginning when they take a left turn, the white lines are approximately 10 feet apart.
    When the is at 220MPH, looking at one frame at a time, the bike covers approximately half the distance between the lines between frames.
    The player reports 30f/sec or .033sec/f.
    So if the bike covered 5 feet in two frames, the speed should be around
    5ft/.033sec = 151 ft/sec = 103MPH.
  17. Vic
    Vic Enthusiast
    6,757
    Nov 12, 2000
    Holy Sheite! Ulysses is da man! Nice quantitative analysis!
    So the speedo is showing more than double the actual speed, so at the end when it shows 100, its not even doing 50mph! Thats what I thought, cuz it looked dead ass slow! Nice "SWAG" technique ya got there. You proved with math, what my eye told me.
  18. Eddie N
    Eddie N Enthusiast
    1,313
    Oct 1, 2001
    Bakersfield, CA
    You guys saying it looks slow are cracking me up. Ever go 140 mph and then slow down? After doing 140 for a few miles 80 mph feels like you're crawling.
    Personally, I don't give a crap if the video is real or not, and I haven't even watched it, I just figured I would point that out.
    Also, speed looks very different on video. The amount of "blurring" in the video has alot to do with the camera's shutter speed. A really fast shutter speed will have less blurring effect.
    Eddie
  19. Eddie N
    Eddie N Enthusiast
    1,313
    Oct 1, 2001
    Bakersfield, CA
    OK...I just watched it for the hell of it. It doesn't say "mph" anywhere on that speedometer, at least no where I saw. Is it possible thats its KPH?
    Eddie
  20. Ulysses
    Ulysses Enthusiast
    3,410
    San Diego, CA. USA
    Quite possible since at 220KPH you would be going approximately 136 MPH. Note the inner ring of numbers. I believe that at the bottom it says KM/H. Also at 105 MPH you would be going approximately 170 KPH which seems to jive with the relationship between the inner and outer rings of numbers.
  21. gthomas
    gthomas Enthusiast
    1,201
    May 21, 2003
    The inner numbers are km/h. Look at it. Clear as day.
    Which would make the outer numbers mph, and they jive in conversion.
    If the bike can go 200mph+ stock, the speedo in km/h would correspond to that. As in, in the inner numbers it tops at 350km/h.
    It wouldn't top out at say, 220 km/h.
  22. gthomas
    gthomas Enthusiast
    1,201
    May 21, 2003
    Now, instead of looking at the external (non-bike) factors in the video, let's look at the internal (bike) factors in the video:
    He WOT at 14 seconds @ 50mph.
    And maxes at 33 seconds @ 220mph.
    The bike ran the 1320 (stock) in 9.95 @ 143.18 mph. click
    In 19 seconds, he went 170mph.
    Starts: first gear
    first shift at 80mph
    second shift at 110mph
    third shift at about 130ish
    fourth shift at about 180ish
    fifth shift at 200mph
    When he reaches 200mph in sixth gear, he is spinning 10,000 rpm's.
    If, as has been suggested, he changed the sprocket but failed to recalibrate the speedo, the rpm's would still correspond to the 'uncalibrated' real speed.
    It would not be redlining in 6th gear if he was going a MUCH slower speed.
    And he got it to 11,100 rpm's in sixth gear.
    That's EFFIN FLYIN'.
    ROCK ON!!! :headbang:
  23. Fast Freddy
    1,312
    Dec 7, 2001
    TUCSON, AZ - USA
    gtthomas - very well said. no matter how you slice it you can't dispute the fact that he maxed out the bike in top gear. you can clearly see in the vid that he shifted thru all of his gears and pegged his tachometer in top gear. even if his bike was geared down which i highly doubt. he still busted 200 mph. and that concludes the lesson for the day :p
  24. gthomas
    gthomas Enthusiast
    1,201
    May 21, 2003
    And I still forgot a word, and a line:
    And maxes the speedo at 33 seconds @220mph.
    And reaches max rpm's of 11,100 in 6th gear @ 50 seconds.
    ROCK ON!!!!!! :headbang:
Share This Page
