HELP!! Brake bleeding
Discussion in 'Tire , Wheel, Brake and Suspension' started by JasonSSG, Nov 3, 2015.
  1. JasonSSG
    JasonSSG Viper Owner
    71
    Apr 10, 2012
    United States
    Just installed Stoptech SS brake line and now bleeding the brakes. Im using a brake vacuum bleeder, starting at the passengers side rear wheel I bled both sides of the caliper, moved onto the drivers side rear wheel and noticed that I cant get any fluid to come out of the lines....then did the same on the passengers front with the same situation. No fluid purging out of the lines. The master cyclinder is full so I know that its not a lack of fluid. Any advise? I know Im possible missing a simple step....do I need to turn the vehicle ignition on while bleeding to allow the ABS module to cycle?
  2. gb66gth
    gb66gth Viper Owner
    1,855
    Dec 10, 2007
    Big-D
    did you have the master cylinder cap open?
Share This Page
