Hot Interior
Discussion in 'General Viper Discussion' started by ramedjr, Apr 28, 2012.
  1. ramedjr
    ramedjr VCA Member - South
    18
    Mar 8, 2012
    Houston, Texas
    Has anybody ever had hot air blowing thru the vents on a cool day from the engine compartment?
  2. Bird325
    Bird325 Viper Owner
    799
    Nov 4, 2009
    Ft Worth, Tx
    HELLO? Welcome to a race car that is street legal! The air system is in the engine compartment and gets hot along with everything else. Run you A/C to cool down the vents and then go to 'outside' air ... usually works for me here in Texas. Plus, both windows down for 10-15 minutes when you take off to clear all the heat sink in the interior and then go to the AC. Nobody ever said it was going to be Your Father's Oldsmobile. :)
  3. BlknBlu
    BlknBlu Viper Owner
    3,514
    May 25, 2008
    Omaha, NE
    I do when the heater is on......lol. Yes these cars run hot on the interior from the engine and mostly the exhaust. GEN IV is about the coolest since the crossover pipe was removed.
    Welcome to Viper
    Bruce
  4. viper67wife
    viper67wife Viper Owner
    277
    Oct 10, 2009
    Eastern PA
    What Gen? Gen 1s are their own story.....
    Diane
  5. 01sapphirebob
    01sapphirebob Enthusiast
    4,962
    Apr 21, 2008
    "OIHO"
    What he said...:)
  6. ramedjr
    18
    Mar 8, 2012
    Houston, Texas
    Thanks I was just wondering, because it does get pretty hot after awhile, but the car is a blast to drive.
  7. ninjakris
    ninjakris Enthusiast
    245
    Jun 27, 2011
    Charleston, SC
    I don't know what gen you have, but I removed all the factory exhaust on my 03 and went with a aftermarket system that elimated the cross over pipes and it does make a huge difference. Everyone keeps preaching it, and honestly I figured they were all just babies. Now that I have done it, I see why. Good luck with the heat. My next project is stripping the interior and doing a layer of dynomat to help with heat and noise.
  8. AJ02
    AJ02 Viper Owner
    334
    Jan 27, 2012
    Azle Tx.
    I Just run the A/C on low with the windows down.:D
  9. ramedjr
    18
    Mar 8, 2012
    Houston, Texas
    I have aftermarket exhaust and I dont know if they removed the crossover, but I am sure that they did. I have a Gen 3.
  10. 01sapphirebob
    4,962
    Apr 21, 2008
    "OIHO"
    I'm not an expert and am not claiming to be but perhaps there could be another issue. I have not heard of this problem (whats mentioned above) with the GEN III's. Maybe someone else can chime in.
  11. viper_itch
    viper_itch Enthusiast
    288
    Feb 25, 2011
    I don't think you have enough cool days in Houston to worry about it. :lmao:
    But yeah, even the gen4 will heat up enough that you need AC here and there on a fairly cool day. Usually I just roll down the windows.
  12. ramedjr
    18
    Mar 8, 2012
    Houston, Texas
    Yea I do to but the heat is coming from the A/C vents. So rolling the windows does help but you can still feel it.
  13. ramedjr
    18
    Mar 8, 2012
    Houston, Texas
    I was just wondering if this is natural or do I have something wrong. Also where can we take the cars to be worked on that the mechanic is a trusted Viper mechanic?
  14. FrgMstr
    FrgMstr Guest
    Brother, it is totally normal. Sometimes it is worse than others. Turn on the AC and boogie on in big HTown.
  15. slysnake
    slysnake Viper Owner
    1,688
    Nov 26, 2007
    Cockpit heat is a well known "feature". Fixed in the Gen4 I believe. Never thought it was bad enough to bother me personally. Run the A/C if you want, that will help. Also, on my Gen 3 vert, the heat from the hood vents rolls into the cockpit on the road when the top and windows are down. They say the Gen4 style hood solves this problem. I will find out this summer. I hope so because I find that more annoying than the exhaust heat.
  16. costanZo
    costanZo Viper Owner
    34
    1,517
    Jan 26, 2008
    Haverhill, MA
    Ditto. :2tu:
  17. Cobraken
    Cobraken Viper Owner
    799
    Apr 13, 2004
    Southern Oregon
    My 1st Viper didn't even have an air conditioner.
  18. VYPR BYT 94
    VYPR BYT 94 Viper Owner
    2,458
    Mar 20, 2011
    Green, OH
    exactly... my 94 had it as an option. I love the rawness of the gen1's. Sort of a nostalgic feel to them - probably explains why I love those old 427 cobras with the plain interior and side pipes. :2tu:
  19. fastandloud
    fastandloud Viper Owner
    389
    Jun 18, 2008
    Frisco, Texas
    Wait...are you saying that even with the vents 'closed' and a/c off you are still getting heat coming thru the vents???
    I don't have THAT issue...mine blow ice cold for about 20 minutes then it turns to warm air. Fully charged a/c warm air....
  20. ramedjr
    18
    Mar 8, 2012
    Houston, Texas
    Yes exactly what I have now the vent may be open to outside air coming in. I turn the air on and the air coming thru the vents is now cool, but not cold.
  21. Slithr
    Slithr Viper Owner
    1,165
    Jun 15, 2010
    Friendswood Texas
    Most of the guy's in Houston trust the work performed by Morgan at Tomball Dodge, give the Service Mgr. a call ... David Milam 281-378(1474) to schedule an appt. Probably a good idea to get it up on a lift and give it the once over, the guys at Tomball Dodge will treat you right :2tu:
  22. ramedjr
    18
    Mar 8, 2012
    Houston, Texas
    OK will do that I have no trust in the rest of the Tomball mechanics for different reasons. I will try him thou for the Viper. Are parts for the car pretty plentiful or do we have to go to outside sources.
  23. Slithr
    Slithr Viper Owner
    1,165
    Jun 15, 2010
    Friendswood Texas
    Tomball Dodge is very proud of their parts, you might be better off shopping at the VPA and having the larger items shipped directly to Tomball (like I did my tires). Sorry to hear about the other bad experiences, I've only taken my Viper there and have always been treated well :2tu:
    MODERATOR EDIT: Link to non site sponsor removed.
    VPA:
    https://www.viperpartsofamerica.com/
  24. Sonoman
    Sonoman Viper Owner
    424
    Mar 10, 2011
    Sonoma Cownty
    On a Gen3 using the vent mode from outside air with no A/C, it does tend to run warm. If you look on the passenger side cowl where the "fresh air" intake is (just below/in front of the windshield), it is directly behind the right side hood vent. So hot air can exit the engine compartment from the hood vent and then flow into the ventilation system, mixed with some outside air of course. On a Gen IV the hood vents are farther forward and I believe the airflow is such that this issue is reduced significantly.
    It is possible to reduce the flow of hot air from the right hood vent to the passenger compartment air intake by blocking two or three of the rear most vent slots on the passenger side. I've seen it done with ~1-inch high-density black foam rubber cut to fit inside the vent slot. Probably not a good idea to block off more than two or three of the slots-- and best to leave them all open for track days or other high speed events.
  25. ramedjr
    18
    Mar 8, 2012
    Houston, Texas
    Thank you I will look at that.
  26. Allan
    Allan Viper Owner
    2,546
    Mar 7, 2009
    La Junta Colorado 81050
    I notice it feels a little cooler in the car when i'm not wearing my helmet. :rolleyes:
  27. ramedjr
    18
    Mar 8, 2012
    Houston, Texas
    LOL I guess not
  28. Viper007Bond
    Viper007Bond Viper Owner
    202
    Apr 22, 2011
    Portland, OR
    Haha, nope. :)
    It's probably not as bad but I certainly have to keep fresh, cold air blowing onto my legs on the long drives.
Share This Page
