How to get rid of UV coloration on white plastic?
Discussion in 'Viper Detailing Tips & Tricks' started by InjectTheVenom, Apr 27, 2012.
  1. InjectTheVenom
    InjectTheVenom VCA Associate Member
    6,859
    Mar 10, 2004
    Hope you guys don't mind me asking here, but I have 2 hard plastic items in white that are discolored from ageing and UV exposure and was wondering if there is anything to remedy this. A nagging memory snippet keeps telling me that a long time ago someone had a substance complete with how-to and explanation of how it worked to undo the UV damage?
  2. uvbnbit
    uvbnbit Viper Owner
    2,151
    May 9, 2007
    Kingston Springs, TN
    plastic polish? sand, then polish?
  3. InjectTheVenom
    6,859
    Mar 10, 2004
    Does plastic polish have some kind of agent in it to dissolve the coloration? Any recommendations that are available in or willing to ship to Europe? Sanding is not an option because there is black text on the showroom plate that needs to remain intact.
  4. uvbnbit
    uvbnbit Viper Owner
    2,151
    May 9, 2007
    willem, can you post a pic of the part? that might help. the "showroom plate" has me a bit confused.
  5. VYPR BYT 94
    VYPR BYT 94 Viper Owner
    2,458
    Mar 20, 2011
    Green, OH
    Isn't the black text raised? If so you should be able to polish around the letters with a flattened stick and felt.
    If it's all flush that's tough. The plastic polish I've used is abrasive just like when they do paint restorations.
  6. InjectTheVenom
    6,859
    Mar 10, 2004
    uvbnbit, this is the plate I am talking about:
    [​IMG]
    Kind of like dealership plates in the U.S. but then for a specific vehicle type.
    @VYPR BYT 94: the black text is ever so slightly raised, I share your concern for any kind of polish being abrasive so when the bottle of plastic polish that I ordered this afternoon has arrived I will need something like you describe.
  7. uvbnbit
    uvbnbit Viper Owner
    2,151
    May 9, 2007
    I too think a polish will take the black off. It might be more trouble than it's worth, but you could put some masking/painter's tape across the top and "carefully" trim around letters with razor blade. Polish around best as possible.? ?
  8. VYPR BYT 94
    2,458
    Mar 20, 2011
    Green, OH
    ITV, you just need to make a little sanding stick to do the job. Take a piece of wood and make it a comfortable/appropriate size or style for the job. Then get some 2 sided masking tape and stick it on the end to hold the sandpaper and cut around it with a knife.
    [​IMG]
    This will help you polish the white areas without hitting the raised black areas.
    You may, depending on the severity of the discoloration, need to start out with as low as 220 grit along with the polish and then work your way up to like 1500 grit. Just don't try to jump too much at one time... go in gradual increments.
    [​IMG]
    I'd be shocked if this doesn't work. Good luck!
    Mike
  9. ViperTony
    ViperTony Enthusiast
    7,555
    Apr 3, 2006
    New plates.
  10. InjectTheVenom
    6,859
    Mar 10, 2004
    And have the appraiser laugh at me for something anyone could have made? Nah, I'm not afraid of a little work :)
  11. thompsonracing
    thompsonracing Viper Owner
    447
    Apr 24, 2009
    Chalfont, PA
    Best thing to do is clean them really well with a mild detergent, such as Adam's All Purpose Cleaner.
    Next, treat them to Adam's Super VRT to restore the low gloss black sheen. Super VRT has a UV protectant and moisturizer so it will keep your plastic from fading. It is also waterproof, so it will last a long time.
    Post some pics of the parts you are working on. Also, email me and I'll get you a bottle of VRT to try.
  12. uvbnbit
    uvbnbit Viper Owner
    2,151
    May 9, 2007
    Just run it over to him real quick. :D
  13. InjectTheVenom
    6,859
    Mar 10, 2004
    He better have Atlantic Ocean sized boots when he does :D
Share This Page
