Purdue_Boiler_Viper
Are you guys permanently mounting the LC-1 switch and LED for periodic calibration? What creative mounting ideas have you come up with if so?
Yeah. I'm looking at the Innovate warning:
WHEN INSTALLED IN THE EXHAUST, THE OXYGEN SENSOR MUST BE CONNECTED AND OPERATING WITH THE LC-1 WHENEVER THE CAR IS RUNNING. AN UN-POWERED OXYGEN SENSOR WILL BE DAMAGED WHEN EXPOSED TO EXHAUST GAS.
So, I guess you guys are peeking through the grill to see if the LED shows normal operation. I was thinking of something in the cockpit. Substitute a NASA looking switch for the momentary pushbutton, and you have something that could look like a rocket launcher.
here's a couple pics of my setup inside the car
I think it is stealthy yet easy to use in the car and looks clean
this is on the panel under the steering column
the headlight switch is to the left of the button/LEDs and the fusebox is at the bottom of the panel
there is only 1 momentary button because I wired the black wires together after the LEDs
I figure there will never be a reason not to calibrate the sensors at the same time
the LEDs are separate to monitor the codes from each sensor
I see this as superior to mounting the LEDs in the engine bay because I will know if the sensor is sending a code while I'm driving
