kw suspention
bluesrt
trying to adjust compression and rebound on some kw,s, these have the piggybacks on them but only seem to have a adjuster on top and nothing else? what way is soft and hard, no manual and its not my car,just trying to soften up the ride for him. just need to know counterclock adjustment and clock,wich ways are soft to harsh. thanks. by the way they adjust with the pin.
rbbugbitme
Rotating the adjuster clockwise should make it stiffer. Sounds like you have V2's that adjust rebound only.
B
bluesrt
Thanks. I havnt seen 2, s with piggybacks.but that's what its lookin like
AZTVR
Chandler AZ
My KW Variant 2 (on a Gen2 ) had only the one adjuster below the upper shock mount. I used an allen wrench as a convenient tool to hold and poke into the adjuster hole and found that you could move it about a quarter turn in the window opening. Moving the allen wrench from right to left (clockwise) takes it toward full hard. There were 13 "quarter turns" from full hard to full soft.
kmagnuss
