Logging A/F with Vec2
SYNFULL
Bucks Co, Pa
I just got finished installing the LC-1 with an XD-16 gauge. Everything seems to be working but I am not sure how to set the vec 2 software for logging. I have the LC-1 going to analog 2 but I don't know what box to select in the vec 2 software where it say's "sensor". I do see viper stock a/f but i don't think that's it.
ViperTony
Don't know if this helps but my Vec3 software has a pre-defined sensor for the LC-1 named "WB_LM1_LC1". Also, great write-up here: http://forums.viperclub.org/illustrated-upgrades/598748-wiring-wideband-o2-vec-guide-photos.html
2001 GTS
Charlotte, NC
You need to call Sean, I went through this same thing.
He will send you the VEC3 program so you can log through that. But you can only write back with the VEC2 program.
SYNFULL
Bucks Co, Pa
Do I need to program the LC-1 for the correct voltage? I read that in another post. If so, how is that done. I didn't get any instructions with mine except a quick install guide- unless it's on the cd, but i only see the logworks program on it.
ViperTony
SYNFULL
Bucks Co, Pa
Tony,
I used analog 1 but I guess I need to reprogram that from a laptop connected to the serial in port?
Sean said to use [FONT=&quot]0V=10:1 AFR and 5V=18:1 AFR[/FONT]
Thanks!
ViperTony
Yes, use the serial port to connect and LM programmer to change the analog 1 output values.
SYNFULL
Bucks Co, Pa
Thanks Tony!
Are going to to tune yourself Gary?
My car was tuned on a dyno last week but is still rough especially in the midrange where it goes from vacuum to boost. I am still learning but I hope to be able tune it myself (and of course hope you guys will advise when needed, otherwise I wouldn't even try:nono:).
Javadog62
