milling gen 1 heads how much
mrbob
davenport iowa
got he 605 lift cam installed and degree ed have the heads ready to send out and have 2.02.and 1.6. valves installed , and port work done , got .027 cometic gaskets . how much can i mill off the heads with the cometic .027 gaskets without making valve to piston contact . i did the search option but could not find a correct answer would like to get to compression to 10.1 or better , thanks to all.
Hostile
upstate NY
Clay the piston to valve clearance then subtract the running
clearance you want that will give you the amount you can deck the heads.
Skeeter
No members online now.
Liberty235
