Misfire ?? Help Needed
madbrian
my 99 gts 12,000 miles has an intermittent misfire.
runs great when on the gas, lots of bucking but not always when going slow.
both throttle butterflies adjusted correctly.
i have changed following and about to throw towel in
plugs
leads
both coils
cleaned all grounds
both oxygen sensors
air sensor
fuel filter
throttle body sensor
map sensor
cam sensor
crank sensor
pcm
both cats ( 1 damaged through misfire )
could it be an injector ? is there an easy way to check which one is at fault.
cheers,
Brian.
Ratical2
San Jose, CA
If it is like my 96, you have 4 O2 sensors, not just 2. The other thing is battery condition. The car has a tendency to do weird things when the voltage is low.
Looks like you have addressed all the other possibilities.
Good Luck and post what you find that caused of the problem.
ViperJohn
Maryland
Is the car throwing a misfire code? If it throwing a specific cylinder code then I would check that injector. You could also switch with another injector and clear codes and see if same code returns or if it has changed to the cylinder number that you moved suspected faulty injector to.
I would also check the wires and one last thing I would check is to make sure your fuel pump is working properly. Best way to check is to buy a fuel pressure gauge and remove your cowl. Run gauge through opening and tape to windshield. It looks bad, but this will allow you to operate the car and check the fuel pressure through the entire vehicle operation cycle. If you notice fuel pressure drop during the bucking, chances are the fuel pump not supplying enough fuel is leading to a lean condition.
I am also curious what type of damage the catalytic converter sustained.
Another possibility is a bad PCM or bad ground to the PCM. I remember reading a few years ago there was a member struggling with bucking and once correcting a faulty ground, the bucking went away.
Calling Chuck Tator is also really good advice.
Good Luck.
Cape Coral, FL
You never said if the car was stock? Is it actually throwing a Misfire code, or just surging...?
M
madbrian
the only mods are headers, hi flow cats, 3 inch corsa cat back, k and n filter , smooth tubes.
i have tried 2 sets of leads, now has new mopar gtsr leads.
the damage to 1 cat consists of the exit side .if you look inside the cat the mesh is approx 3 inches further in than it should be and it looks distorted in shape not flat mesh like it should be.
the pcm has been changed for a brand new 1998 one and the grounds have all been cleaned and extra grounds have been fitted.
there are no misfire codes
mainly the car just surges and often clunks from the drive train while this happens. it goes great when you step on it,
the battery never fails to crank the car over so seems fine.
any ideas??
cheers
plumcrazy
ALL OVER
battery cranking and being fully charged is different. if you dont know the age of the battery or its 4-5 years old, replace it
M
madbrian
the battery is over 5 years old , its very strong with no obvious signs of failure.
white out
The Mitten
+1 for the injector.
how old is the fuel in the car?
have you checked the timing?
any vacuum leaks?
fpr or fuel filter could be causing an irregular flow.
Nick
Daddy Long Stroke
Did it ever throw a code that you cleared? Sometimes they don't seem to come back.
Did you replace the 'front' two 02 sensors, or the 'rear' ones?
Jack B
NE Ohio
any ideas??
cheers
Can you clarify whether the surge is low or high vacuum and at what rpm.
M
madbrian
fuel is new in tank
both o2 front sensors are new
fuel filter is new
checked fuel pump relay is in correct
can't find vacuum leak
the surge is at low revs below 2500 revs approx
have not changed rear o2 sensors
have not checked timing
the car has not shown a code
do you think it is possible there is crap or water in the gas tank?
Jack B
NE Ohio
fuel is new in tank
fuel filter is new
Low or high vacuum - in other words, light pedal or way into the pedal? Is it a surge or is the car bucking.
1. The rear O2'S won't affect it.
2. Have you actually put a OBD reader on the car.
3. You cannot mechanically change the timing.
4. Are you sure the drivers side throttle opens slightly before the passenger side.
Cape Coral, FL
Without more detail, this is TOUGH.
Personally, I would lean towards a leaky injector or a bad O2, which caused the cat to fail. I have also seen coils & PCM's that are intermittent, and you will go insane chasing them [usually gen-1's] The plugged cats make the surging worse. As we all know, most Vipers, especially 92-99, have a bit of low-speed buck.
On that note, I have seen:
1. Injectors/plugs/coils/O2's/etc causing cats to fail, misfires, surging.
2. Cats fail for NO apparent reason, causing surging. Car was gone through top to bottom, NO other issues found, cat replaced, and did NOT ever reoccur. Still cant explain it, but I have seen it a couple times.
M
madbrian
it happens at low vacuum and the drivers side butterfly slightly opens first.
i checked it with a rowe obd reader, will this be good enough to display the fault?
is there an easy way to locate which injector is at fault if any ?
thanks!
GTSnake
Motor City
If it has not thrown any codes I would lean more toward the fuel system. Sounds like an injector issue.
Joseph Dell
Atlanta, GA 30338
And that 5 year old battery. I know you said it was cranking strong, but it is cheap insurance to replace it. If it isn't dead now, it will be soon.
+1 on cleaning the injectors. Also, clean our your idle air control motor. That pesky thing sticking off the passenger side of the intake near the alternator. They often stick open or closed.
Good luck!
M
madbrian
the tps has been replaced, no difference
i have cleaned the idle air control, no difference.
i think it is time to buy a battery and clean the injectors.
can the battery temp sensor cause this problem?
perhaps something has been tipped in the gas tank before i purchased the car?
i remember being in a gas station once and while a moped driver was paying for his fuel, 2 arseholes rammed gravy and chips into his tank.
Jack B
NE Ohio
If the issue is at low vacuum, that little devil (IAC) shouldn't be part of the problem.
If you remove the injector connectors one at a time, you can hear/feel a slight roughness at idle each time you pull the connector. A totally dead injector won't change the current engine rhythm. That is a lot of trouble and the oem connectors are junk, you might end up worse for the ordeal. The rpm won't change much since the ECU will try and compensate for the lost injector.
You could probably also watch IAC and if there is no change when you pull the bad injector you will not see a change in the IAC position. If it is a intermittent injector issue - good luck.
Jack B
NE Ohio
I just had Tony Armour balance my injectors - quick turn-around. If you do that, change the connectors to the MSD type, this way you will have ruled out an injector problem. It could still be a single coil-pack.
M
madbrian
both coil packs are new and i fitted msd connectors ( the ones with a wire retaining clip that click when connected )
i think it is time to remove the injectors and get them tested.
do you think injectors can go bad at 12,000 miles?
cheers!
white out
The Mitten
Just pull the injectors from that bank (both for extra security) and take them to a local shop to have them bench flow tested and cleaned.
If you don't have one local, Deatschwerks is a very reputable company and would do it for a reasonable price. But your car will be down for a few days.
Nick
M
madbrian
can any one tell me if all year viper gts injectors are the same ?
i saw some on the net for sale and they listed different injectors for different year cars.
Bobpantax
Miami
Have you tried a simple cure like disconnecting the battery for a period long enough to clear out all of the adaptives in the controller and then seeing if the problem is still there after you reconnect?
Viper123456
