NARRA specs fire extinguisher info needed.
VIPER GTSR 91
Spring, Texas
For TT1 NARRA specifies a min. of a 5 lb. extinguisher (not 2.5). So far I cannot find a 5 lb. with a Gen 3/4 specific seat mount, only the 2.5 lb. Where can I get a 5 lb. and a bracket that will fit the seat and the bottle? Thanks
Viperless
MN
5 lb fire extinguishers are readily available. You may have to fabricate your own mount though. I made a simple one out of mild steel. Made two bends, drilled two holes, and bolted it to the floor using the two front seat track bolts.
FrankBarba
What about tying both of them together ??? 2 2.5 would work.....
