NEW Affordable! Gen 3 Adjustable Lowering Kit!
GTS-R 001
California (north)
A couple of months ago, I decided to lower my Gen 3 coupe and in doing the research on feedback from various individuals about the current options out there I found that there is a big performance / price variance. My findings were as follows
Caps
- $150 - $200 plus shipping depending on vendor,
- No determinate spec on quality of product
- Lowers car .5 inches, some claim more but the facts are the facts
- Unadjustable
- DIY-able - yes
- Install labor $300 to $500
Eibach Street Kit
- $329 - $500 plus shipping depending on vendor
- Lowers car approx 1 inch
- ride quality - Bouncy
- DIY-able - yes
- Unadjustable
Combination of Caps and Eibachs
- $479.00 to $700.00 plus shipping depending on vendor
- Lowers car approx 1.5 inches
- Ride quality bouncy
- Unadjustable
- DIY-able - yes
- Upgradeable ability NONE - sell or throw away and go with complete new high end system
KW Variant 2's, Moton Club Sports, Penskes.
- $3500 - $6000 plus shipping depending on vendor
- Lowers car approx 0 - as low as you can go
- Ride quality Stiff but Good (race car like)
- Adjustable height
- Adjustable dampening
- Adjustable rebound
- DIY-able - not usually
- optimal Spring rates 500lb front - 800 lb rear
- Allows corner weighting
Most people that can afford or justify the $4K - $6K for the high end systems do in fact go that way, but a lot of these people never "adjust" the rebound and dampening after original set up etc. they just drive
Given the above and the fact that I have owned and tried tried all 3 of the high end systems, I set out to "get the best of both worlds, as much as I could put together, with an upgrade path to the "high end" and as much adjustability as one could expect for the price.
What I came up with is a set up that specs as follows
VIPAIR PERFORMANCE KIT
- VCA price $995 plus shipping
- Pro Kit which includes helper springs $1295 plus shipping
- Adjustable height
- DIY-able - YES
- Upgradeable - keep the springs for use on High end systems
- Lowers weight per corner
- All components made from T6 6061 Aircraft quality Aluminum and anodized for evtra surface strength
Here is before and after shots of the car with and without the kit. The car can still go down an inch or so but I have a steep driveway and a large splitter on the front so I can only go sooooo low.
Before
After
Here is a pic of the standard adjustable kit
Here are some pics of the kit installed on the shocks
Here is a pic of the "PRO" Kit which includes the helpers to keep everthing in place
Rear prototype installed
Front Prototype installed
Rear new weight
Rear Stock Weight
Front New Weight
Front Stock Weight
witz323
Delafield, WI
wow, this really came together well. I'd like to do my suspension next summer, and this seems like a great option. Thanks for all the info, and don't be surprised if I'm contacting you next season. I'm anxious to see how they perform for you this summer.
FLATOUT
Man I can't wait to get a set of these!
Looks awesome!
Andy Wheeler
Shadowman
Great job
What keeps the threaded sleeve from turning on the shock body when adjusting the spring perches?
Takes care
Shadowman
G
GTS-R 001
California (north)
Great job
Takes care
Shadowman
Shadow,
Great question,
With the acme thread on these things, the nut does not like to move at all with any force on it. That is why I:
1) went with higher spring rates so that there is no need to pre-load like the stock suspension
2) The sleeves are super tight slip fit and the fronts are a different ID than the rears as teh shocks are slightly different OD between front and back
3) I placed 2 set screws on the bottom of each sleeve to hold it in place
4) the rear shocks actually have a slot in them that the set screws fit in on one side (slot is for install and remove from the black fork)
Hence they do not slip when loosened or tightened ( I also encountered this on the protypes so I made adjustments to avoid this very thing.
Thanks for the question!
G
GTS-R 001
California (north)
Steve,
I'm very interested, have you tested these on the track yet?
Thanks,
Robert
Hi Robert,
No I have not, but that is why I went with the spring rates that most Moton guys go with. I think that the only way you will do better on a track than with these is to part with another $3K+.
You are damn close to me, any time you want to meet up and show me what you can do at Infineon with a set of these, I would be glad to meet you and I have a good relationship with a performance shock place at the track there that helped me make my prototypes that would help us get some track settings right.
PM me or email me some time
Thansk
Steve
ILLSMOQ
SAN JOSE, CA
Steve, you should sell a bunch of these. I always wondered why no body had come out with a kit like this. Finally an affordable alternative to full blown coil overs.:2tu:
Nine Ball
Houston, TX
How does that threaded section attach to the front shocks?
What is the benefit of the "Pro" kit? Won't all those items just bunch together once installed on the car anyways?
I would like a set.
Tiago
Houston, TX
cool.
what is the spring rates on the eibachs? I thought it was the same as what you include in your kit?
G
GTS-R 001
California (north)
I would like a set.
Nine Ball,
YES,
It all bunches together,, it only really helps if you are jumping your car, which according to Chuck Tator, he has a customer that does just that!!!! and it also helps for those who jack their car up lots, other wise just make sure everything is centered and lower the car and it will all line up fine, I don't have the helpers on my car, but some people like the extra stuff, even people with Motons, some use the helpers and some don't.
Hope that answers your question.
G
GTS-R 001
California (north)
cool.
500 lb fronts
800 lb rears
That is what I had on my Motons when I had them and that is what is on my proto's on teh car now and they feels pretty damn good
G
GTS-R 001
California (north)
ILLSMOQ,
Thanks, Your positive opinion means a lot, I know you have done most of your own work and I respect your opinion.
Thanks!:2tu:
Nine Ball
Houston, TX
500 lb fronts
800 lb rears
I think Tiago meant what rates are on the standard Eibach lowering kit. The OEM spring replacement kit. If the spring rates are the same as this kit, how does that change the ride quality?
G
GTS-R 001
California (north)
The Eibach Street kit .....
Good Question, Nobody knows, Eibach will not disclose and the street kit springs are progressive not linear, so the spring rate changes as the spring compresses. The suspension in the viper is made and tuned to work best with linear spring rate springs, not progressives. This is probably why some people don't like the ride with the Eibach Street kit,
Shadowman
Shadow,
Great question,
Thank you for the answer
Your system is very well thought out and looks stunning
All the best
Shadowman
Shadowman
Nine Ball,
YES,
FYI I use the helpers on the Penske systems and I like them because when the suspension is unloaded the spring remains on their perch; a detail nit however mechanically it makes no difference.
Takes care
Shadowman
Tom F&L GoR
Wappingers Falls
Glad to see this. I did exactly this on my Gen 1, but had to machine the upper shock bushing loop and upper spring "hat" on the body. Both were too large diameter to fit the threaded sleeve over. After that, however, same as this project: stock shocks with adjustable height and pick your springs.
I have 550/800 on my Gen 1.
FLATOUT
Awe Damn can't wait to get my set and do a full wright up on them!
Andy Wheeler
G
GTS-R 001
California (north)
When will you be ready to sell these? What colors can be ordered?
Selling already,
I have red sleeves with Gold caps and Gold nut, with the eibach red springs
or Blue sleeves with Gold caps and Gold nut, with the eibach red springs
I am shipping sets out on either Tuesday or Wednesday coming up.
I have had a lot of activity on these so contact me ASAP to make sure you get yours on this first production run
zrt1465
I would like to order the pro kit, can you pm me with all the details. Thanks
2002_Viper_GTS_ACR
Charlotte, North Carolina
Wouldnt these work on a gen 4 also? (non ACR of course).
More importantly to me, what is the stock spring rates vs these? If this is just about lowering the car, I dont really want to lower my car anymore. Corner balance is nice, if I can find a local shop that can do this, but most importantly I am wanting to get rid of that 'softness' that exists in the stock setup when doing rapid turning menuvers.
So again, if this is just to lower the car and corner balance the car, not that big of a deal to me. If its stiffer springs, that help roll-over/leaning, then I am interested.
Thanks!
Jon
G
GTS-R 001
California (north)
Thanks!
Jon
Jon,
Stock Spring rates as follows:
2003-2006 SRT-10:
Front: 200 lb/in preloaded by 3+inches = 600 lbs preload (approx)
Rear: 500 lb/in preloaded by 1.5 inches = 750 lbs preload (approx)
2008-2009 SRT-10:
Front: 210 lb/in preloaded by 3+inches = 630 lbs preload (approx)
Rear: 525 lb/in preloaded by 1.5 inches = 787.5 lbs preload (approx)
I say approx because the initial compression of teh spring is slightly less that teh rates above.
The rates of the springs that are included in the kit are the SRT10 club sport settings of 500 front and 800 rear, this gives you a stiffer ride than stock (just as on motons etc.) but is well within the operating capacity of the stock shocks due to the pre-loading of the stock springs.
So to effectively answer your real question about will it give you stiffer handling in the twisties - DEFINATELY, is it bouncy - NO, does it feel better - YES, do I have a biased opinion - OF COURSE,
I can only tell you that my 06 coupe now handles better than my 2000 GTS with a full penske race suspension and it "feels" like a race car on the street, and I can raise or lower it in my driveway with a jack and a spanner wrench in a matter of minutes. In fact it takes longer to drive teh car onto the ramps I need in order to get the jack under neath the car than to adjust the suspension for the height
Viper123456
