New Hoosiers
CCBrian
Nor Cal
Finally got my CC running right and now playing catch up for the rest of the year. I was on Tirerack web site and noticed Hoosier no longer makes the R05's but a new R6 tire. And they do not make a 305 anymore...only a 295 or a 315. What is everyone running up front now? What is the new VRL tire sizes? Thanks!!! Brian
C
CCBrian
Nor Cal
Thanks Janni! Also, what tire pressures do you recommend with those hot/cold? I also read today at the Hoosier web site that they recommend at least 3 degrees negative camber?! Are you running that much?
Brian
Janni
Raleigh, NC, USA
We're running the VRL Hooisers - so I am sure they ar enot recommending that for them- they may for the RS06, etc. Not familiar with those tires.
We're running about 1.4-1.8 neg front and about .7 to 1.1 neg front - depending on whether it's a right hand turn course or a left. I don't think that you can get to -3.0 in a CC with the stock eccentrics or the camber shim kit.
We run about 38+ PSI hot. Staggered starting pressures based on left / right turn abuse and about 3 psi less for the rears. can be roughly 29F and 26R, +/- 1-2 PSI based on which side gets leaned on more.
Others like the pressures much lower - like 32-34 hot.
Your mileage may vary. :laugh:
sloth
