Now available gen 3 viper power steering line replacements
Discussion in 'New Products and Supplier Specials' started by JTS VENOM PERFORMANCE, Sep 25, 2012.
  1. JTS VENOM PERFORMANCE
    JTS VENOM PERFORMANCE Enthusiast
    117
    Apr 8, 2011
    Denver, North Carolina
    GEN III VIPERS
    available in black fittings with steel braid $209.97
    http://www.shop.jtsvp.com/product.sc?productId=600&categoryId=242
    also black fittings with black covered steel braid $219.97
    http://www.shop.jtsvp.com/product.sc?productId=599&categoryId=242
    GEN III VIPER POWER STEERING LINE KIT, replace those leaking power steering lines with JTSVP lines.The Lines are high pressure crimped braided hose with an fitting adapters to convert your oem lines to new braided hose. Hoses replace the oem line from the power steering pump to the hyrdraulic fan and from the fan to the steering rack. comes with all neccessary hardware and two lines. We just upgraded the fitting in the power steering pump with a new custom fitting for a better, easier leak free install. A fairly easy install resulting in better steering feel and no leaks.
  2. Allan
    Allan Viper Owner
    2,546
    Mar 7, 2009
    La Junta Colorado 81050
    Does the line swivel at the pump end? -like the oem connector :eater:
  3. JTS VENOM PERFORMANCE
    117
    Apr 8, 2011
    no sir, that has been the cause of many leaks from that fitting, ours does away with the fitting and you actually get a new valve to go into the pump itself, we have sent out many kits to viper owners and supply dealerships line kits for installation on the cars and trucks.
    thanks
    Sawyer
  4. jk
    jk Viper Owner
    338
    Oct 3, 2000
    Richardson, TX USA
    The product description says "For off-road use only" - what does that mean exactly for a power steering fluid line?
  5. JTS VENOM PERFORMANCE
    117
    Apr 8, 2011
    We are required to put that in the description for liability issues since it is part of the steering components
    we dont know the mechanical experience of some of to whom we are selling, and although installation is straight forward and fairly easy,
    it is suggested that an experienced tech do the install
    We make it as easy an install as we can with the best components, and constantly upgrading them
    as we strive for the best. We actually jsut changed the fitting that connects to the power steering pump to a one piece
    unit, which replaces the flow valve in the pump for easier installation and less prone for leakage.
    We have sold thousands of these in the past few years, and tons to actual dealers, We had a dealer tell us the other
    day that he had a problem vehicle in his shop that they had installed 2-3 sets of oem lines and still had problems, he called
    dodge hot line and they forwarded him to us, whether true or not , I cant say, jsut what he told me.
    But if anyone ever has a problem with the install, I am usually available 24/7/365
    below is some pics of ones we did in blue for a customer.
    stinkers lines and GN exhaust 011.jpg stinkers lines and GN exhaust 023.jpg stinkers lines and GN exhaust 026.jpg
  6. Shandon
    Shandon Viper Owner
    1,450
    Dec 18, 2006
    Northern Kentucky
    OMG!!! Do my Eye's deceive me?? You all have produced a replacement for the total Piece of Crap OEM Power Steering Lines? I'm heading to your site now to buy!! I hope these hold up better on my track car then the OEM stuff.
  7. JTS VENOM PERFORMANCE
    117
    Apr 8, 2011
    yessir, got the order and will get it right out for you sir
    thanks
    Sawyer
  8. ninjakris
    ninjakris Enthusiast
    245
    Jun 27, 2011
    Charleston, SC
    I just had these installed in my 03' and they look great. Very high quality. I didn't do the install myself because lack of tools but it doesn't seem too hard. If anyone is on the fence about this, look at it this way. A new OEM line and connector from a dealer is about $300. This kit replaces two lines and actually fixes the issue instead of just prolonging another failure with the OEM setup. I also made a call to JTS and they have great customer service. thanks again.
  9. JTS VENOM PERFORMANCE
    117
    Apr 8, 2011
    thanks for the kind words sir, need anything jsut give us a hollar
    Sawyer
  10. TowDawg
    TowDawg Viper Owner
    2,105
    Feb 13, 2010
    Chattanooga, TN
    I just replaced my power steering pump a few months ago. If I had known about these then, I would have done it while I was in there.
    May get around to it this winter during some down time. Although I just bought a trailer and think I might get out of hand with customizing it. I tend to have that problem. ;)
  11. JTS VENOM PERFORMANCE
    117
    Apr 8, 2011
    we do a little of that also sir
  12. TowDawg
    TowDawg Viper Owner
    2,105
    Feb 13, 2010
    Chattanooga, TN
    STOP IT!!! ;)
  13. JTS VENOM PERFORMANCE
    117
    Apr 8, 2011
    LOLOL yessir, we have a local guys 97 GTS in here now , putting a set of GG heads on , and belanger headers, and doing a small amount of underhood enhancements, it probably will not be what most find tastefull
    but is what the customer wanted, so far looks pretty good, when we get the heads from greg and get it all installed I will post up some pics and results sir
    thanks
    Sawyer
  14. JTS VENOM PERFORMANCE
    117
    Apr 8, 2011
    Just a warning to all,
    if ordering from JTSVP this holiday season, you package may be sent signature required
    sorry if this causes an inconvenience but there is a holiday problem of
    folks following the delivery trucks around and stealing packages as they are left
    at homes, just another way we are trying to look out for our customers.
    thanks
    Stinker
  15. agdetail
    agdetail Enthusiast
    246
    Oct 5, 2011
    vancouver, bc
    how much are you selling the upgraded steering pump?
  16. CHAOS
    CHAOS Viper Owner
    59
    Nov 22, 2009
    Vero Beach Florida
    Do you sell the lines individually? The only one I need is the pump to fan line.
  17. Vital Velocity
    Vital Velocity Viper Owner
    380
    Dec 15, 2008
    Dickinson, TX
    Back from the dead for this thread. Does anyone have a contact number for the company? I need to see about getting a set sent overnight
  18. Allan
    Allan Viper Owner
    2,546
    Mar 7, 2009
    ..........This is a difficult market to survive in.
    If you can't just type JTS Venom in your search engine and have their info come up, the may have found out how hard it is to have a business like that and folded.
    Hopefully not.
    Apparently guys like Roe, SPT, A&C, PartsRack, Snakeoyl and such have somehow figured out how to manage in a limited marketplace.
    We as Viper owners are lucky to have the vendors and service guys that we do.
  19. rosco
    rosco Enthusiast
    53
    Feb 4, 2012
    i purchased these lines almost two ears ago. They went on quickly but you had to remove the factory fittings on the pump and fan, a bolt on adaptor, but it was no biggie.
    they look great and worked for almost two years. the two lines were touching each other on the left side of the engine bay. Just from touching, the vibration of driving wore a very small hole in the STEEL SLEEVE on the hose.
    it started spraying fluid from that tiny leak over the whole belt assembly, which in turn caused the belt to slip as well as loosing the pressure to run the cooling fan,
    i contacted JTS, they said tuff luck. only guaranteed for six months. buyer beware.
    in hindsight, some installation instructions would have been nice with a warning to not let these pretty lines touch anything that vibrates. Or provide rubber mounting grommets to secure the lines and separate them.
    i recommend you DO NOT throw away the factory fittings you need to remove to install the lines. if you do you will be committed to BUYING another set of lines to replace these if yours fail. The guarantee is very short for industry standards. Even auto zone gives you a year on the crap they sell.
    A better solution is to take your old line to a hydraulic equipment company, an air craft hydraulic company, or even a local NAPA store and have a fitting pressed on to the old line to replace the swivel fitting of the factory line.
    i am sure these lines worked lovely on a test bench. Where nothing vibrates and you can test them one at a time without them touching something else. but if it had a quality hose benieth the STEEL SLEEVE, it should not have ruptured because the STEEL SLEEVE had a hole worn into it. They should also offer a lifetime replace ment on the hose itself. Like most hydraulic hose companies do. Like they do with their oil lines.
    i give it two stars. one because it fit, another because it was pretty. durability, zero, ease of getting a replacement, ZERO. been a week and still waiting. 500 bucks into this thing now. should have used factory replacement, they lasted a good six years,
  20. ViperJeff
    ViperJeff VCA Legacy Member - UT/AZ Staff Member
    3,735
    Sep 26, 2010
    Idaho
    Really.......
    He always promoted them as lifetime over on the truck forum. I wonder what changed
  21. rosco
    rosco Enthusiast
    53
    Feb 4, 2012
    yep, that's why i bought the kit.
    apparently, the lifetime warranty does apply to their oil lines, but not the power steering hose.
    it was a bit of a rude surprise. the first of which was the failure of the hose itself. i have steel braided lines on high pressure fuel
    lines on my boat and brake lines on various cars and have never had one fail. ever.
    But the man said six months, cant/wont help you. not even with expedited shipping. been a week and still waiting for replacement.
    personally, if it were my company i would have sent out a replacement for free in return for the failed lines. a hundred bucks
    is dirt cheap for some positive advertising.
    buyer beware
  22. ViperJeff
    3,735
    Sep 26, 2010
    Idaho
    hmmmmmmmmmmm.....
    He's always been a little better than most in customer service (However, not surprised)
    Disclaimer: I'm not a "Stinker" fan (his name before the business). Great guy when it benefits him, not so great when he owes somebody else. learned the hard way
Share This Page
