Open aluminum trailer needed.
Discussion in 'Texas: Houston' started by VIPER GTSR 91, Nov 20, 2012.
  1. VIPER GTSR 91
    VIPER GTSR 91 Viper Owner
    3,789
    Apr 11, 2003
    Spring, Texas
    Anyone have for sale or know where the best place to get an all aluminum (no paint) open car trailer in the Houston area. Is Big Tex the best place? Im needing a new or almost new all aluminum open LOW clearance entry/exit trailer that does not need boards added to drive on. I also need the front air dam that has the tire rack behind it or similar set up. Trailex or Featherlite possibly. Thanks
  2. Nine Ball
    Nine Ball Enthusiast
    3,411
    Aug 30, 2007
    Houston, TX
    The trailer you seek doesn't exist. I looked for a long time to find an all-aluminum tilt back or rollback, but nobody makes one that is all aluminum. The rollbacks are all steel with just an aluminum deck.
    My Aluma 20' tilt can be modified easily with aluminum fold-out ramps from Pitpal, to get the lowest of vehicles on it. Member RCC did that to his. Basically reduced the approach angle a lot, and added the extension ramps to the end. I bought the stuff, just haven't installed it. Big Tex on I45 North sells the Aluma trailers.
  3. Slithr
    Slithr Viper Owner
    1,165
    Jun 15, 2010
    Friendswood Texas
  4. Smokin' 2
    Smokin' 2 Viper Owner
    566
    Jun 11, 2007
    The Woodlands, Texas
    I really like my Sloan but as Tony mentioned the only thing aluminum is the deck. Our gas expedition towed it with a full set of slicks and four 5 gallon jugs just fine. My F350 tows it like it's not even back there. I just used it last weekend to go to MSR-H since I took the Green ACR (with windows).
    If you have a track alignment with ride height around 3 inches on the front (My black car) you will need a board on each side to clear with the track extension on. If you are 4 inches or taller at the front (like K's Green car) you can pull on without a board.
    I would assume you will need a board with a Sloan though. Good luck Mark and let us know what you go with.
  5. B & R
    B & R Viper Owner
    248
    Jun 11, 2008
    Houston
    Also like my 20' sloan, not sure there is a tilt back you can get on without some help. Just bought race ramps 5.5" trailer ramps and these seem to work great. Just used them the first time this weekend with our enclosed trailer and were great. Sloan's are made up in Sherman and he can build to your specifications. Built a custom front end for hauling a set of slicks, a winch and room for tools/gas cans/etc for the three of us.
    Richard
  6. VIPER GTSR 91
    3,789
    Apr 11, 2003
    Spring, Texas
    Thanks to all who responded. Good info from all and I will go by Big Tex as no shipping involved and the Aluma with hinged pit pal ramps may be the ticket but hope he has the options I need too. Is the 18 foot unit long enough or is the 20 really necessary? What length pit pal ramps to assure no rubbing on splitter? They have multiple sizes, or maybe Tom at Big Tex can make up some that are hinged on? Does the Aluma require electric operation or is it manual like the Sloan? I like the manual idea so no battery problems and extra maintenance. Thanks
  7. AZTVR
    AZTVR Enthusiast
    2,990
    Aug 28, 2005
    Chandler AZ
    I have a Sloan; but, the Aluma looks like a good lightweight alternative.
    I saw one this past weekend and did some research to learn some more about it. Looks like no electricity involved.
    This is funny: http://www.youtube.com/watch?feature=player_embedded&v=rIfFGY26lY0
    http://www.youtube.com/watch?feature=player_embedded&v=JL5ljQVMXpY#!
  8. George Farris
    George Farris Viper E-Member - South
    1,259
    Oct 12, 2000
    Canyon, TX USA
    Sloan Works!!
Share This Page
