Re: Group Buy On SCT Handheld Flash Programmers
Sean Roe
Jacksonville, FL
Hi Everyone,
We have a thread going in the Group Buy section, but I've received multiple emails and a couple PM's that people can't reply in the thread.
Here's a link to it:
http://forums.viperclub.org/special-group-buys/613050-group-buy-sct-handheld-flash-programmers.html
I'd like to switch it over to this forum instead.
If anyone has any questions, or would like to start a running list, this is may be a better place to do it.
If you want to be on the "interest" list, please copy below, add your forum name a post. The next person would add theirs and so on until we see how many people are interested. The end number will determine the discount level. It just can't go below $500.
SCT Group Buy Interest:
1. Name : Year / Model
FE 065
MI
Name : Year / Model
1. 2k6voi9 2006/Coupe
2. FE 065 : '01 ACR
radta7
Roselle, IL
what's a typical increase on a 97 with headers, exhaust, rt cats, smooth tubes and filters?
CROM
Fairfax, VA
1. 2k6voi9, '06 Coupe
2. FE 065, '01 ACR
3. Parisianviper, 01 RT/10
4. Chuck Greggs S Arizona ACR, ACR
5. Canyon707, 99ACR
6. CROM, 98 GTS
CROM
Fairfax, VA
For those who can't read: :D
2. FE 065, '01 ACR
5. Canyon707, 99ACR
6. CROM, 98 GTS
7. viperflex, 2004
Ricketts
Fayetteville NC
2. FE 065, '01 ACR
5. Canyon707, 99ACR
6. CROM, 98 GTS
7. viperflex, 2004
8. 281cammer 01 GTS
Sean Roe
Jacksonville, FL
I'm not sure what octane of gasoline you're using, but it can vary.
Basically, the HP gains come from two factors.
#1. Making the air / fuel ratio flat and ideal.
#2. Optimizing ignition timing for the gasoline you're using.
The farther the A/F and timing are from ideal, the larger the gains. If you've done a lot to increase air flow and are on 91 octane fuel, the gain will be smaller as you can't run as much ignition advance and the increase in air flow automatically improves the otherwise excessively rich AF ratio above 4,000 RPM.
Here's a typical stock Gen3 using 93 octane. Only mods before flashing were Mopar cat-back and high flow S&B air filters. This is about what one would typically expect on either Gen2 or 3. Sometimes more is gained at lower RPM when the engine is running too lean there. A larger torque gain can result from adding the fuel needed.
CROM
Fairfax, VA
SCT Group Buy Interest: (Pulled some from the other post)
2. FE 065, '01 ACR
5. Canyon707, 99ACR
6. CROM, 98 GTS
7. viperflex, 2004
8. 281cammer 01 GTS
9. Dimitrios, 05 SRT
10. ViperVon, RT/10 Year?
11. MTGTS, 01? GTS
FE 065
MI
If you've done a lot to increase air flow and are on 91 octane fuel, the gain will be smaller as you can't run as much ignition advance and the increase in air flow automatically improves the otherwise excessively rich AF ratio above 4,000 RPM...
I've made a number of changes to increase airflow, and Sean's comments have me concerned about the actual gains I might get with the SCT. I'm going to take my name of the list for now while I think it over and maybe contact Sean again..I might jump back on before the deadline.
2. Parisianviper, 01 RT/10
3. Chuck Greggs S Arizona ACR, ACR
4. Canyon707, 99ACR
5. CROM, 98 GTS
6. viperflex, 2004
7. 281cammer 01 GTS
8. Dimitrios, 05 SRT
9. ViperVon, RT/10 Year?
10. MTGTS, 01? GTS
Sean Roe
Jacksonville, FL
Keep in mind that we don't put the same tune in all the boxes. We set the program according to the modifications. If headers have been added for example, we add more fuel, primarily above 4,000 RPM where the headers have the larger impact.
The statement about the AF changing with modifications is 100% relative to the gains to be had. The closer a tune is to ideal, the less there is to be gained with changing it.
If you have time, it's always best to dyno and see where your engine stands in regard to AF and power numbers.
Dimitrios
Queens, New York
20-30 rwhp gain for $509 is totally do-able. ill take one!
have K&N instake w filters and corsa catback and RTech hi-flo cats. should i dyno and ge AF ratios first?
FlyBy
Sounds good to me -
4. Canyon707, 99ACR
5. CROM, 98 GTS
6. viperflex, 2004
7. 281cammer 01 GTS
10. MTGTS, 01? GTS
11. FlyBy: 2000 GTS
cyaford
Nashville, TN
4. Canyon707, 99ACR
5. CROM, 98 GTS
6. viperflex, 2004
7. 281cammer 01 GTS
10. MTGTS, 01? GTS
11. FlyBy: 2000 GTS
12. cyaford, '97 GTS
Sean Roe
Jacksonville, FL
Hi Dimitrios,
No need to dyno before. We have that combination covered and know what to do.
The box will have three tunes in it, plus saves the stock one.
If you want to verify or check the gains after getting the flash programmer, go to the dyno and run the stock program and the one you select for your fuel octane.
If a change is needed for any reason, simply email or fax the dyno file or graph along with your box serial number. We'll change the tune if needed, free of charge. So far, of 60+ units, we've only had to tweak two programs, so I think we have it pretty well sorted out :)
Regards,
Sean
YELLOH
Cape Cod, Mass
4. Canyon707, 99ACR
5. CROM, 98 GTS
6. viperflex, 2004
7. 281cammer 01 GTS
10. MTGTS, 01? GTS
11. FlyBy: 2000 GTS
12. cyaford, '97 GTS[
13. YELLOH SRT-10:2tu:
Sean Roe
Jacksonville, FL
$500 - 509 Group Buy SCT Handheld Flash Programmers until the 25th, GTS, RT/10, SRT
so how soon can i get one?
We need to hit a volume point to get the discount from SCT that we're going to pass on.
The plan at this point is to make the GB available until next Friday, the 25th. If we hit 25+ before then, we'll go ahead and order the quantity from SCT and can start processing them for everyone immediately.
We'll print a copy of the list from here and people can either call or email to get the GB discount price.
We don't do Group Buys much and can tweak the process if needed.
YELLOH
Cape Cod, Mass
4. Canyon707, 99ACR
5. CROM, 98 GTS
6. viperflex, 2004
7. 281cammer 01 GTS
10. MTGTS, 01? GTS
11. FlyBy: 2000 GTS
14.Viper 210, GTS
Sean Roe
Jacksonville, FL
Just so you guys know, there are a couple people that have sent me PM's or emails directly that do NOT want their names posted on the forum list, though they're interested in the GB.
If someone has interest and doesn't want their name on the board for it, send me an email at [email protected] and I'll keep your interest private. Considering we have a week to go and not a lot of people know about it yet, the chances of getting everyone $90 to $100 off looks pretty good!
Regards,
Sean
vipervegas
I'm interested, put me on the list.
2001 GTS, K&N in stock air box, smooth tubes, Random Tech cats and catback CORSA. Can't wait:drive:
ViperTony
i like to get my hands on one before our NY/CT dyno day just to see the difference..is this possible?
That's pretty neat in that you can do a before/after on the same day. I wonder if you sent Sean a dyno sheet if he could get you a custom tune?
- Tony
YELLOH
Cape Cod, Mass
Nine Ball
Houston, TX
Sean, can we get one with a Paxton tune? I have a Paxton and 3" catback (stock manifolds, high flow cats)
sloth
