replica of nadines mamba
supraking85
burrnley, UK
hiya all, after deciding **** viper is the best looking in the whole world. im after doing a replica in 1:!8
its the white on without the blue stripes
so take one normal, 10 year old, red 1:18 bburago model viper
and strip it
will sand it down, clear off the badges and attempt the coupe rear end and the side skirt extensions. and the comp coupe bonnet. before it gets some primer and some white
Fatboy 18
Surrey, United Kingdom
Hope you don't have the same fit issues as Nadine did! That rear end took one hell of a lot of work to make it fit!
Nadines at VOI 12 so drop her a PM to this thread :)
Good Luck :)
supraking85
burrnley, UK
already spoken to her via pm :)
i have bought some modelling plastic and will probably end up roughly doing it, im a man of many bodges :) i think ill be putting the plastic form the rear of the door all the way back, and right over the top to the other side. then cutting it to let the boot open.
as for the bonnet, try and smooth out the front duct and fill with bodyfiller, then cut some more grills in it over the top. will try and take my time with it
as i said to ***, if it even slightly close to teh original ill be a happy guy. and thanks for the interest. im sure ill need that good luck :)
Fatboy 18
:) I used to spend hours and hours making models, I was into Tamya 1/35 WW2 stuff then started on the 1/24 scale Hot rods and Funny cars :) The film American Graffiti was a massive influence on my life style :) When I left school and went to Art College, My interview at Art college involved me showing my models, and I was accepted on the spot :)
Please keep us posted on progress of works :)
Mark
UK
supraking85
burrnley, UK
sweet. i wish i did something alot better with my life. how i pine for a viper :)
probably wont be too quick with it, but will do my best. will deffo keep you all updated
ash
supraking85
burrnley, UK
took some harsh sand paper to the badges. grind them down abit, so the rear bumper and the sides are now smooth
will get to sanding it all down once i have abit more time to spend with it
Fatboy 18
thanks mark. will sand it down tonight i think
No Problem,
So just how detailed is this car going to be? I don't know if Nadine has sent you any more pics but there are many differences on her car ;) The front hood is a lightweight hood held down by race clips and pins. On a normal Viper wings are fixed. On Nadine's car she has moulded the top of the wings onto the hood making it all one piece ;)
So if you wanted to go the whole way you will need to cut the top of the wings off and attach them to the hood ;)
I will see if I can find some pics for you :)
supraking85
burrnley, UK
ive been hoarding pics, but there few and far between :) have asked for some more. but will have to wait till shes back across the pond
i doubt ill be moulding in the wings, but am aiming for a smoothed out front duct, and cutting in the extra vents across the middle.
the sides wont be moved out, but i will be adding the extentions to the bottom of the skirts.
rear wont be a perfect rep. ill still have the vert rear end, but will try my best to get the overhang over the lights and along the bootlid.
as for the snake skin spraying, im gunna do my best to get it as close as possible. but im not sure how yet :)
and jance, yes unfortunatly its an early bburago model. which came with a damn gen2 engine :( i would swap but im not breaking up my autoart coupe for parts :)
Fatboy 18
So the two wings (white bits) are attached to the black bit, making it a one piece
Note Hood pin (left hand side of pic)
Here's a better shot
Front of engine X brace Left side
The Engine :D
supraking85
burrnley, UK
thanks mark, ive not seen that pic before
ive got that one though, which gives a good overall image. still not sure if i would be able to pull it all off, plus once the bonnets off its only going to show that gen2 engine :) so may just leave it
supraking85
burrnley, UK
given it a bit of a sand with 600 grit.
next job, cut out the bonnet vents :rolleyes:
supraking85
burrnley, UK
ok, the good news is the extra slats in the bonnet are done
the bad news is there rough as old boots, ive split one into the side vent. and ive cut into some other areas.
hopefully though once painted it shouldnt look too bad
im going to leave the front duct, too much of a paint to cut and fill it in.
Fatboy 18
Get a Needle file and put a slight angle on those slots :)
You can get a bit liquid metal from a hobby shop or DIY store and patch up any holes you have made :) Or use epoxy 2 part filler :)
Well done so far :1up: :)
supraking85
burrnley, UK
ive given them a slight (ever so slight) angle. but i think doing that is what snapped a bit. so theyll do :) ill probably just run with some filler primer on the bonnet
thanks
supraking85
burrnley, UK
after trying damn hard to get the rear end done, i think its well beyond me. so will get the sides done then get it in primer this weekend
supraking85
burrnley, UK
thanks, i bought a tin of gloss white today. so once its in primer and dry i can do the white straight away, let that dry then do the black
supraking85
burrnley, UK
got it in primer (pics to follow) but the bonnet jsut looks poo, think ill just wrap the bonnet black, but will paint the rest
supraking85
burrnley, UK
pics
wheels primered and painted
car primered
and painted white
wheels are lacquered and ready to go, car i need to let dry and harden fully before i even think about masking it up. but it shouldnt be too hard to do
supraking85
burrnley, UK
ok, two glaring mistakes. first is i forgot to set camera to macro so it hasnt focused :( sorry
second is my masking was **** (or its bled abit) but either way it looks good from a distance
supraking85
burrnley, UK
think here lies the answer to my problems
gunna cut it in vinyl stick it to the car with some mesh and spray it the gold-ish
Nadine UK GTS
Bath, Somerset, UK
Just found this, absolutely brilliant, fun to see it taking shape and paint. So pleased you like my MambaX to make a unique model.
When I had the ideas about what I wanted to do with the car, I thought about taking a 1/18 model and trying out some of the mods / ideas, as I'm no good at photoshop. Anyway, I was too keen to get going, and went full scale straight away, so its great to see you making a model.
supraking85
burrnley, UK
thanks nadine, means alot.
atm the project has stopped, i ran into some problems trying out some snake skin (abit like you i rushed straight in rather than testing on something else first) so it needs sanding back abit :(
ill find some motiviation this week and get back on track
Fatboy 18
:eater: Chop, chop :D
I remember years ago using a plastic material called Frisk Film, you could take take a print from a magazine using the film and then transfer it to your model. It was used for car custom painting (big in the 70's)
Google it ;) Lots of stuff on the market for image transfers :)
supraking85
burrnley, UK
:) i think im probably gunna be better off cutting a full vinyl image, and sticking that down. then painting the gold. it worked well with the centre bit (posted above) but didnt fancy weeding it all out to do the rest of the scales
Dsalameh
