Reverse Locked Out - HELP!!!
Discussion in 'SRT10 and SRT10 Coupe Discussions' started by Flexx91, Apr 19, 2008.
  1. Flexx91
    Flexx91 Viper Owner
    1,007
    Mar 18, 2002
    Houston, Texas, USA
    Beautiful Saturday afternoon and I want to take the car out for spin. Can't get the damn thing into reverse. WTF!!! Never had this issue before.:mad:
  2. ROCKET62
    ROCKET62 Has Left the Room!
    2,392
    Mar 6, 2003
    Phoenix, AZ bye-bye IOWA
    Does it not move over to the reverse gate, or can you not shift up into reverse? Unless there is a mechanical issue with the shifter/linkage, you should be able to manually override the reverse lockout if that's whats causing your problem. It takes about 2-3 times the force of normal shifting, but can be done without issue. Reverse lockout solenoid has been known to go bad and is easily replaced.
    Good luck.
  3. VIPER GTSR 91
    VIPER GTSR 91 Viper Owner
    3,789
    Apr 11, 2003
    Spring, Texas
    Put the car in backwards next time. Just kidding. Hey Flexx, if you dont get it fixed, call Tomball Dodge where I get all my work done and they will fix it right the first time. Great tech. Harold is their over all service manager. Good luck with it.
  4. PaViper
    PaViper Enthusiast
    2,316
    Jan 21, 2004
    Agreed, you should be able to force it if it just the lockout, if it won't go into gear, that would be another issue......haven't heard anything since yesterday, does that mean you got it in to reverse or did you make a door in the back of the garage
  5. Kai SRT10
    Kai SRT10 Viper Owner
    1,562
    Feb 4, 2004
    Salt Lake City
    Check your fuses. A blown fuse can cause the reverse lockout solenoid to not function. Lots of folks have this issue after a header install (melted insulation on wires, causes short, causes blown fuse, causes solenoid to not work.) Don't know if you've got headers or not, but check the fuses anyway.
  6. viperfuntime
    viperfuntime Enthusiast
    203
    Mar 16, 2008
    San Diego
    Anybody know where the reverse lockout solenoid is located. I have the same exact issue. I have to muscle it into reverse to get it in gear. Is this something I can do in my garage and where is the best place to buy this solenoid?
  7. V10BAT
    V10BAT Viper Owner
    73
    Oct 22, 2004
    BERKSHIRE ENGLAND UK
    Hi mate.the rev lockout solenoid is just below the shifter in the gearbox body.see the long
    large thing bolted to the case,it has a small electrical plug on the end.this is a 99 rt/10 g/box.but seems to look the same as an srt .you will need to get the car in the air,take off the big tunnel plate,then you should be able to get to the solenoid.chuck tator for the part
    or go to your nearest dealer.:2tu:
    ps you could check you have voltage at the plug with the key on
    [​IMG]
    [​IMG]
  8. viperfuntime
    203
    Mar 16, 2008
    San Diego
  9. V10BAT
    V10BAT Viper Owner
    73
    Oct 22, 2004
    Hi bud
    ok pic time
    [​IMG]
    heres the thing.if you get in the car and turn on the ignition you should have voltage
    to the solenoid.important bit.less than 5mph,the pcm provides a ground for the solenoid
    (energized) and allows shifting into reverse.greater than 5 mph the solenoid is deactivated
    and prevents the trans from being shifted into reverse.
    i would er more on a bad connection at the plug than a fault with the pcm.more likely its the thing that has to do the work ,the solenoid.two things ,its got to have voltage ,and its got to have a ground.all this while its stopped key on.
    lastly the solenoid is threaded into the left side of the trans.if you look at the pic,it may undo right where the arrow point is.the new solenoid should tell you more on that.
    hope you /and the op get it sorted :2tu: Dave
  10. viperfuntime
    203
    Mar 16, 2008
    San Diego
    Great information. I will check it out and see if it has power first. If it does, I will replace with a new one. Thanks for all the diagrams and knowledge.
  11. Viper X
    Viper X VCA Member - South
    3,471
    May 1, 2004
    Had the trans removed a few times for clutches. Once in a while the tech forgets to plug it back in. Same issue.
    Good luck.
  12. viperfuntime
    203
    Mar 16, 2008
    San Diego
    Problem Fixed!
    I purchased a new reverse lockout solenoid from the Dodge dealer. Spent my $130 and proceeded to use my dads car lift to get the car up and go to work. After getting the bellypan off the car, I realized the solenoid had nothing plugged into it.
    I looked all around and after 15 minutes realized the harness that plugs into it was zip tied to my fuel lines running along side the tranny. I believe a vendor who I will leave unidentified for now was the one who did the zip tie when putting in a lightweight flywheel and never plugged it back in after the install.
    I cut the zips and plugged it in started the car to test it and it went into reverse like it should.
    I reattached the bellypan and was in business like 1.2.3.
    Its rare things go this smoothly for me when it comes to auto repairs but if anybody needs a new solenoid I have one and will sell it at a discount.
  13. viper k
    viper k Viper Owner
    963
    Feb 20, 2008
    do you have solenid and much thanks vipe k
  14. ViperJeff
    ViperJeff VCA Legacy Member - UT/AZ Staff Member
    3,752
    Sep 26, 2010
    Idaho
    This thread is from 2008, sorry
Share This Page
