Shifting to second gear on gen 5
Kyarb
Kuwait
Hello,
Id like to introduce myself to the members as a new owner of 2017 ACR GTC.
Im facing a problem in shifting gears from first to second. This issue happened few times now but im not sure if its a common problem or not.
The gauge says "Skip to 4th gear" as if there is no 2nd gear at all.
Bonkers
DelaWhere? USA
Its the skip-shift override. Its a mandatory feature on manual transmission
vehicles built here in the US to help with fuel mileage (mpgs) and emissions.
You have three options:
1) Live with it.
2) Rev the motor to above 2500rpm every time you shift (bypasses the cut out)
3) Buy a Skip Shift Eliminator off ebay / JonB - its a 5min plug in part that locks
the solenoid and prevents the bypass from engaging.
