So you want to share a log or map.....or anything else
D
DAMN YANKEE
Guest
Here is a simple solution to share a VEC map or log.
Just follow this link and post your files to this free web site.
http://www.mediafire.com/index.php
Use the "browse" button to find your file on your computer...then hit upload.
When you are done and the file is uploaded....remember to "copy" the link and paste it into your thread so others can find and download your file.
Steve 00RT/10
Michigan
Here's an earlier one from the gray car Dan -- before the 4 feet of snow :mad:
http://www.mediafire.com/upload_complete.php?id=kekm9xkecym
Let me know if I did this right. I was able to download and open it. It's actually a pretty good run........going from 2750 RPM or so to 5250 RPM in about 3.6 seconds in 3rd gear.
Roughly 47 MPH to 91 MPH. Not bad for the old LND RKT.
AF line is flat, but could a tad leaner. Still playing with the IAT function percents. Hoping to get a little more tuning in before Gingerman next week. Still haven't figured out the correlation between heat soak and maintaining 11.5 AFR?
As for reading this file -- remember mine is an upgraded VEC 2. I use the General DataSet ID 108
Steve
D
DAMN YANKEE
Guest
Steve...
Not a complete site address..Can't pull the file down. Cant be with the "..." in the middle.
Please try again.
sloth
