Speedometer and Changing Wheel/Tires sizes
Vipera Russelli
How much would the speedo be off if you put 20" all the way around on a Gen III? Or 19" in the front and 20" in the rear on a Gen III?
Anyone know where to get a speedo calibration certificate in Northern VA?
Luke@tirerack
Re: Speedometer and Chaning Wheel/Tires sizes
providing you keep the proper overall tire diameter there would be no difference
this picture explains it very well
V
Vipera Russelli
Thanks Luke. I should have been more specific. Some folks here are filling up their wheel wells with larger wheels AND larger tires. I've done a search and can't seem to find what size tires these guys are using, but let's assume we're switching to 19" in front and 20" in the rear and using the same tire side wall as stock, so as to fill up the wheel wells while maintaining the stock rake. How much would you expect the speedometer to be off actual speed with this set up?
Luke@tirerack
the rear SRT10 tire is 27.4" tall which is about 5% off of what you are loosing ..... so when your speedo says 105 mph you are only going 100 mph
Nader
New York
I am interested to know whether the height of a 345/25/20 Pirelli is tall than the 27.4" stock tire height.
Luke do you know?
Blue Batmobile
San Diego, California
Isnt therev a website you can punch in your wheel and tire size and see the equivalent on upsizing? I know I've seen it before.
Bat˜
Javadog62
