Vapor Leak
Discussion in 'SRT Engineering Q/A Area' started by CajunViper, Mar 28, 2012.
  1. CajunViper
    CajunViper Viper Owner
    326
    Jul 25, 2000
    Gonzales, LA
    I have a vapor leak on top of my gasoline tank. The dealer said I have to cut the pan out of the trunk to access it. Is this the only fix. How often has this happened.
    Dean
  2. speedracervr4
    speedracervr4 Viper Owner
    1,348
    Dec 9, 2006
    Lancaster, PA
    How do they know It's on top of the gas tank
  3. CajunViper
    326
    Jul 25, 2000
    Gonzales, LA
    They checked everywhere else a leak could be.
  4. bluesrt
    bluesrt Viper Owner
    5,011
    Nov 17, 2008
    they probably did a smoke test on it to find it
  5. Tom Sessions
    Tom Sessions Enthusiast
    48
    808
    Oct 3, 2000
    Hampstead,NC.
    I just fixed a large evap leak in a 08 coupe. You can access the fuel pump module and the hoses going to the canister and Leak detection pump through fuel pump access hole above the tank. And you can also see the canister from under the car if you remove the rear diffuser panel and move the heat shield under the tank. Pm me if you would like a little more info.
  6. bluesrt
    bluesrt Viper Owner
    5,011
    Nov 17, 2008
    ther ya go, this would be your best bet, he has been ther^^^^^^^^
  7. CajunViper
    326
    Jul 25, 2000
    Gonzales, LA
    Thanks Tom, we will try that.
Share This Page
