VEC-II Abnomalies
Discussion in 'Gen II' started by EllowViper, Mar 6, 2011.
  1. EllowViper
    EllowViper Viper Owner
    55
    1,654
    Mar 28, 2006
    Valrico Florida
    Anyone experience their VEC acting up when it gets hot (the VEC that is)? I seem to be having a situation where my VEC craps-out once it gets hot under the hood Seems to be OK when cold). Possibly from getting wet a few times. I cleaned the circuit board a few times (corrosion on the aux box) but it doesn't really solve the problem. Basically when I go WOT under a hard load after the VEC gets hot, it takes a dump and faults out. My AFR goes into 9.0 and the engine loads up bad (Ty can explain if from following me). Can't accellerate and knocks to holy hell. At this point, I do a rolling key-off/on to reset the system and away I go...until I try and do it again. Closed loop drivability at this point sucks as well...so I think my VEC is totally screwing the pooch. No CELs or anything on the PCM. Need to shed the VEC and go 100% SCT I believe.
  2. plumcrazy
    plumcrazy Viper Owner
    50
    16,232
    Jun 9, 2003
    ALL OVER
    or AEM.....
  3. Red Snake
    Red Snake Viper Owner
    2,048
    Feb 18, 2007
    NashVegas
    I see from your sig that your car is boosted. You should just send the VEC in to Sean Roe and get it refurbed. ;) Problems solved.
  4. EllowViper
    55
    1,654
    Mar 28, 2006
    Valrico Florida
    Sent the VEC into Sean a few years ago and had it upgraded. Called him about it and he basically stated that either the unit works or it doesn't and if I sent it in, all they could do is to verify its operation. From all outward apprearances, it seems to be working. I might have to try and pull a few logs when it craps out just to see what its doing, but most of the time when I'm logging, the software locks-up and dumps the log anyways. Really runs great when the VEC is cold. It starts acting up after I shut down and let it sit and then strat up and drive. Seems to get heat soaked IMO.
  5. Red Snake
    2,048
    Feb 18, 2007
    NashVegas
    Is there anyone near you with a VEC? Just swap them out and load your tune in there. You'll know right away if the VEC is your problem or not. ;)
  6. 99 R/T 10
    99 R/T 10 Enthusiast
    10,315
    Jun 4, 2001
    Enterprise, AL USA
    Hey Ellow, if you need to borrow one, PM me.
  7. EllowViper
    55
    1,654
    Mar 28, 2006
    Valrico Florida
    PM sent...we'll see where this leads...
  8. EllowViper
    55
    1,654
    Mar 28, 2006
    Valrico Florida
    Sean got back to me and it appears that I've been running the injector driver box for low impedance injectors on my high impedance injectors...so how about that! Didn't think that was possible but its been that way for years. Sean recommends I remove the injector driver box and try it. So I guess it must be a fairly straightfoward disconnect.
  9. Red Snake
    2,048
    Feb 18, 2007
    NashVegas
    Cool. Hopefully it's a quick fix. :2tu:
  10. EllowViper
    55
    1,654
    Mar 28, 2006
    Valrico Florida
    Well, the drama continues. Sean and I have been trading e-mails on this trying to figure out what I have. Apparrently, the driver box I am referencing is indeed required, but Sean indicates that there are also additional peak and hold driver boxes that can be plugged into the harness. He thought I was talking about one of those. I guess what I have is the standard configuration "The small box with wires at one end is the load board for the stock PCM injector return signal. Do you have an injector resistor box? It would be between the VEC output and injector harness input."
  11. 1TONY1
    1TONY1 Enthusiast
    5,661
    Dec 19, 2001
    Dalton Ga. (Chatt. Tn.)
    The extra box goes in the harness for the injectors. Only the black Mopar injectors need it, green or dark blue tops do not.....those are the three injectors Roe has used to my knowledge. You may have some other kind though. Swap the Vec box and see what happens.
Share This Page
