[Video] Secondary cats gutted on my 06 Corsa
AbsolutHank
Odenton, MD
I made a couple video's a few weeks back with my 2006 coupe, with only a 2.5" Corsa Track Catback. In anticipation of a full header/HF cat exhaust next spring, I didn't want to go crazy on exhaust work now, and waste good money. I decided to gut the secondary cats on my OEM converters, to give it a little more sound, and to help with the footbox heat. I'm very pleased with the sound, and how the tone has changed. Mid to upper RPMs have really improved, and the sound down hear idle/cruising is just a tad higher...perfect! The popping has picked up as well, so to 98% of the members, that's a plus...I personally hate it:D So, except for my own labor, a nice free mod:2tu:
I purposely took the first set of video's in the exact same spots as I knew I would be doing this comparison today. The driveby sounds pretty similiar in these video's, but it's definitely a different sound in person.
Don't forget to watch in HD!
http://youtu.be/c43sgyRJHSw
http://youtu.be/Fw_IMReBho8
Here are the original video's I took a few weeks ago:
Revving
http://www.youtube.com/watch?v=mo-rbInlqd4
Drive-By
http://www.youtube.com/watch?v=SjJm7I2e8eQ&feature=related
VYPR BYT 94
Green, OH
I like it! Smart... especially with what you are planning on doing in the spring, I think was a great move that didn't cost. At least this way you can get your "fix" to hold you over until Spring :)
SlayerLS1
MD
Still sounds great! What method did you end up using to gut them?
DaDood
Maryland, USA
Nice vid Ryan. I still think your lowered Viper with that color combo is what makes your car awesome!
Can't wait to see it with the new wheels.
cubican
Frisco , TX
The Corsa and the guted cat give you a great sound, I had that set up before doing the headers, and to be honest I wish I stayed with that set up. The header where expencive and not much of a change to justified the cost.
A
AbsolutHank
Odenton, MD
I just used an air hammer to break the material into small enough pieces to grab out of there with a set of long reach pliers. It was more difficult and tedious than I had read about though...
A
AbsolutHank
Odenton, MD
Thanks Brian...I'm exicted too! Tumbler will be lookin pretty awesome as well :)
A
AbsolutHank
Odenton, MD
Very, very interesting...can you tell me what header/cat/catback combo you're running Pedro?
ViperGeorge
Greenwood Village, CO
Any reasonably competent exhaust shop can remove the clean up cat (the one farthest down stream) and replace with a straight pipe. My shop made a jig to hold the pipes at the correct angle and then welded the new pipe in. Doug Levin told me to do this rather than gutting the cat. Worked will on my SC 06 with Corsa exhaust.
A
AbsolutHank
Odenton, MD
I agree 100% if this was a long term mod...refer to my first post:
"In anticipation of a full header/HF cat exhaust next spring, I didn't want to go crazy on exhaust work now, and waste good money."
cubican
Frisco , TX
Im using the full bellanger set up with HF cats, then I replace the mufflers with the Corsas I had. At first the Drone was to much for me, with the corsas that got much better but not gone 100%. And for the dyno # only 7hp extra with the new set up. as for the sound is some what better but not much at all.
slysnake
I guess this would increase the exhast smell pretty strongly, correct? I would love to improve the exhast note, but don't want to increase the smell.
Sonoman
Sonoma Cownty
I was under the impression that the Corsa track system removed the secondary (downstream) cats. Is that incorrect? I did not install the Corsa system on my '05 myself, but I can't for the life of me find a second/downstream cat on the car. Is it inside the sill area? What I see is header collector, cat converter (above the circular bottom pan openings), then the exhaust disappears into the side sill.
cubican
Frisco , TX
I had no problems with the smell, the one cat was plenty to do the job, and a big sound difference.
A
AbsolutHank
Odenton, MD
Here is a picture of the OEM cat...maybe it's possible someone already removed the rear cat, or it already has high flow cats installed?
Big Turkey
Houston, TX
I have gutted cats before and it's a PITA. Never reccomend it to anyone and i own a shop!
I just ordered a set of American racing headers and magnaflow catback. I loved the Corsa on my Vette but after hearing them on the viper with headers it was not deep enough for me.
I will post up some vids for comparison, thanks for the vids absolutehawk I actually watched your vids about 20 times before making a decision.
No members online now.
thiagets
