OEM replacement inner & outer tie rod end kit.
Not available through Chrysler (must be ordered with steering rack). This is an inexpensive replacement to a part that commonly fails.
Toe link kit also available.
Complete steering rack or toe link kit includes 2 inner rod ends and 2 outer rod ends
Also sold seperately
The following tests are performed to ensure the performance and quality of our sway bar links: Material Surface Crack Test Hardness Test Roughness Test Fatigue Test Vibration Test Stud Breakaway Test Stud Pull Out Test Welding Tensile Strength Test Buckling Test Salt Spray Test Leakage Test SAE J193 Ball Stud and Socket Assembly Test Procedures
Order Now
