Guys...The response I left was given to me by David ***** ...I was asking the same question a few weeks ago. This reply is by him...see below...direct any questions to him.
Thanks, Dave
By Dave ***** :
I am lurking today and having fun online since the rain won't let me play with my supercharged baby...
In 1999, Chrysler deemed it necessary to change the pistons due to several reasons. Most were the escalating transmission complaints and the quick to replace a tranny dealers who were scamming the factory for new trannys.
Another reason was emissions, but not entirely. The actual emission output is exactly the same as it was in 1997. In some cases it is worse.
The newer pistons are different as well as the rods. The different parts will not interchange between years. With the lumpy cam you could run a much stronger forged piston and have lotsa torque. It also worked very well at higher piston speeds. The offset of this was greater thermal expansion and skirt slap. When you soften a camshaft and everyone wants power, you have to find it elsewhere. The intake was already close to max effiency and the heads could not be modified without having to recertify the engine. The only other change that could be made was to change the piston design.
What is different is that the hyperpathetic pistons are a high silicon content design. With this they are thermally stronger to a small window. This allows a closer piston to wall clearance which leads itself to less blowby, lower tension rings, and reduced emissions. In addition to this, Chrysler engineers wanted to be sure that they kept the power levels up so the wrist pin weight was changed. You see, when you take valve duration away from the cam you have to get it somewhere else. So, they raise the pin height in the piston to increase its dwell time at Top Dead & Bottom Dead Center. This adds greater cylinder filling and more squench with every revolution. Another reason why Creampuffs respond SO well to nitrous and supercharging.
The drawback is that once the peak thermal limit has been reached for a hyperpathetic piston, it flakes or cracks away. It literally self destructs. It will not hold its heat treating and will shatter like glass. Forged pistons will hold their structure, yet will actually melt at much higher temps due to the slow annealing process in their heat treating. This is why forged pistons are the ones of choice for all big nitrous and forced induction applications.
What can be done? You can ceramic coat the Creampuff slugs and forget the problems, or buy a $1000.00 worth of new forged pistons. Ceramic coating costs about $500.00 and is worth gold plating. Ford now supplies ALL its new 4.6 and 5.4 engines with ceramic coated pistons. They do this to reduce all scuffing and to eliminate all possible piston failures with their forced induction systems.
Just some good .02c worth.
Visit the ViperNation.com site and post there. Find the real tech answers on this site, not just speculation. Of course, one of you can cut and paste this to the VCA page so all can read it....
Have a Great Weekend!!
David A. *****
832-282-4004
http://www.davidawilks.com
