Whats everyone using?
01sapphirebob
"OIHO"
So whats everyone using (for those that do this) to clean the underside of their Vipers? I was thinking about using 409 since I have plenty of it and it's a good all purpose cleaner.
steve911
Cottage Grove, Wi.
I use 409 here too. It works really well in getting rid of raccoon remnants. It's fall here and they are worse than deer some nights.
bluesrt
thompsonracing
Chalfont, PA
Do you plan to clean it while on a lift or on the ground? You can simply pressure wash the underside on the ground. If you're on a lift, you need to work a little cleaner. I recommend APC, like Carmen said.
01sapphirebob
"OIHO"
I plan to do this on a lift. My '01 is asleep for the winter now so I put it on the lift so I could clean underneath when the opportunity presented itself. I will have some time tonight since I will be washing my '08 tonight so I might get under the '01 to clean her up a little bit.
Javadog62
