Which Tilton Cluth/Brake Pedal Assembly is used in CC?
repiv
Alos, is there a mounting bracket that DMS sells?
Nadine UK GTS
Bath, Somerset, UK
I wasn't aware that they made anything, like the GTS-R which had its own pedal box (not street car set up) but the Comp Coupe uses the Gen3 street car pedal box. I fitted this special build adjustible bias GT2 pedal box in an ABS / servo delete, it was made using AP Racing and Tilton parts, and floor mounted in the car. I really liked it, much better set up for racing. Pic shows the Comp Coupe street car parts I removed, with the new system, total weight saving was over 10lbs.
randythomas
How much weight does it have before having the new ones? 10 lbs is significant weight reduction is it?
sloth
