Willow Springs Testing 1 2 3 14" Rotors Pic's
Dave's Big Brakes
San Diego Ca USA
Willow Springs Testing 1 2 3 14\" Rotors Pic\'s
A great day for the Need for Speed :D testing new 14" rotors and new Big Reds :D
closeup for new 14'rotors and Big Reds
rear testing on April 22nd :2tu: stay tuned :D
Santa's Sleigh
Re: Willow Springs Testing 1 2 3 14
Yo Dave>.
It sounds like the big SRT brake calipers on the front of your GEN2 is just what the doctor ordered. If it feels that good on the track with just the fronts, I can only imagine how good it's going to STOP with all 4 corners covered.
Do you think having the ABS will help in adjusting the front to back perportioning?
What do you suggest for the none ABS VIPERS?
Hurry up! Can't wait to stop like the SRT'S.
BillO
D
Dave's Big Brakes
San Diego Ca USA
Yo Bill :D Having the ABS will keep things in balance for the 01-02 cars.
For the non abs cars, I'll have hopefully 2 choices :usa:
First, all 4 SRT's with a pro valve, and second, moving the fronts to the rears (brackets are be made right now), like Archer did and he won a lot of races should cover that.
I'll be installing the rears tomorrow if everything goes right.
Final testing is Aril 22nd. :usa: :2tu:
Here's a pic of all 4 brackets for the SRT upgrade
Bugeater
Virginia Beach
Dave,
I think your 2 choices for Non-ABS cars, technically, are identical. Some of my notes that I have show the Non-ABS front caliper piston sizes = SRT rear. So if you already have your front calipers and dont care about the styling differences of using an SRT front with GenII front (on the rear) that is the best choice money-wise.
You will *definately* need a rear prop valve. For both choices. My calculations may be wrong, but look at the stock front/rear bias differences between the 2 models...
SRT-10 Brakes:
* Brembo 4-piston front and rear.
* Piston sizes: 40/44mm front, 38/42 rear.
* Rotor sizes: 355/32mm front and rear.
* Piston Area front to rear ratio: 52.43%
STOCK VIPER:
* 4-piston front, 1-piston rear.
* Piston sizes: 38/42mm front, 36mm rear.
* Piston Area front to rear ratio: 83.2% (horrible)
For reference:
Surface Area of Piston. SA of circle = pi (3.141592) x Radius Squared
44mm = 1520.53 2 pistons = 3041.06
42mm = 1385.44 2 pistons = 2770.88
40mm = 1256.64 2 pistons = 2513.28
38mm = 1134.11 2 pistons = 2268.22
36mm = 1017.88 2 pistons = 2035.76
30mm = 706.86 2 pistons = 1413.72
28mm = 615.75 2 pistons = 1231.50
Calculations for SRT vs Non-ABS GENII:
GENII 2770.88 + 2268.22 = 5039.1F, 1017.88R = 6056.98 Total Surface Area. 83.19%
SRT10 3041.06 + 2513.28 = 5554.34F, 5039.1R = 10592
Total Surface Area. 52.43%
D
Dave's Big Brakes
San Diego Ca USA
Bill O,
Spacers are for caliper clearance on different wheels, ACR, and VR1's don't need spacers, stock 18" do, but 1/4" should make all wheels clear.
Bugeater(there out in force this year :eek: )
Thanks for info, but on Gen2 pistons, I can only measure 38/34mm, and these are off my 02. Any ideas?
Silver Snake
San Diego, CA
Well this is really starting to look promising. I am seriously interested in moving my fronts to the back and adding SRT calipers to the front, but I am only interested in this setup if I can HAVE A PARKING BRAKE! Just busting your chops buddy! :laugh:
BTW, you can't post a picture of your new brake kit with such road rash on your nose! You would do better to find a nice Silver ACR to show off the new brakes. I may know someone local that can help out in this area.
Keep us posted!
Mark
D
Dave's Big Brakes
San Diego Ca USA
Mark, How's this :2tu:
Talk about a fast fix job :D
P/B calipers will be after the rest of the kit is finished(I don't use one anyway :D )
Silver Snake
San Diego, CA
I gotta have my e-brake, it comes in handy when performing J-turns! ;)
BTW, not sure who your body shop is, but they are damn good. You gotta give me their info.
Mark
SingleMalt
Hey Dave -- Judging by how much an increase in fluid volume you're looking at, I hope you're opting for a Gen III master cylinder. There's no way you're going to safely pump enough fluid on a stock master.
Be safe!
Mike
D
Dave's Big Brakes
San Diego Ca USA
Mike, it's waiting in the wings to be installed if needed :D :2tu: One step at a time. :cool:
When you have a Race Yellow car, it stops better :headbang:
Everything is working out just fine, takes time doing it right.
Bugeater :D Your right, :2tu: after pushing out pistons, they do measure 4mm bigger than what goes on the pads surface.
Stay Tuned :usa:
Bugeater
Virginia Beach
Hey Dave,
Sorry I havent called...I will promise, if to simply congratulate you on your work...
Once I guinee pig ABS on my car, your setup will be added!
So glad to see these options getting worked out. We'll all have the brakes that the GenII should have had from the factory for non-viper tax prices!
D
Dave's Big Brakes
San Diego Ca USA
Test day now postponed until May 13th :( stuff happens can't make Fri, then vacation until the 8th :cool: This stuff just takes a lot of time to make sure everything is 1000% :usa: :2tu:
So far, the fronts are 11+ :2tu: Can't wait to get my Big RaceYellow Calipers on :headbang: RaceYellow will STOP better.
Stay Tuned
D
Dave's Big Brakes
San Diego Ca USA
Well, parts is parts, :eek: ) Final all wheel testing begins on Monday !!! Can't wait, so I can get my poser RaceYellow Calipers on :eek: )
Willow Springs testing will be either next Friday, or the 3rd of June(I feel the need for speed)
The light in the tunnel is really bright!!
Stay Tuned
D
Dave's Big Brakes
San Diego Ca USA
Mark, still testing rears :cool: :2tu: , this is a slow project :usa: , but there's a really big light in the tunnel :D :usa:
Still need to do Willow Springs again, for final testing. Give me a call :cool:
carl B
United Kingdom
Dave
Do you have any plans on fitting the emergencies off of the SRT-10 as well??
Carl
D
Dave's Big Brakes
San Diego Ca USA
Hey Carl, Yes, down the road as soon as both rear brkts are done. I have the pieces, just need time to make brackets. :usa: :2tu:
High speed testing should be done on 6/10/05 :2tu: :usa:
carl B
United Kingdom
I checked with my parts guy and he tells me the SRT master cylinder is different to my 01 are you considering changing to the later one?
D
Dave's Big Brakes
San Diego Ca USA
Hey Carl,
That's on the list to try out but, I measured the pedal travel before and after installing the new brakes, and the travel was the same. So far so good, final testing is June 10th on a high speed road course :2tu: :usa: :D
The light in the tunnel is getting bigger :cool: :2tu:
D
Dave's Big Brakes
San Diego Ca USA
Yeh :2tu: testing is now complete for my big brakes, boy does it feel great to have real brakes :D :headbang: :usa:
I'll post pic's, and some more info Sun or Monday.
Stay Tuned :2tu: :usa:
D
Dave's Big Brakes
San Diego Ca USA
Just waiting to make sure I'll have parts buy Friday :cool: , then I'll post some pic's on the final product.
I'll post on New Products & Suppliers Special shortly, have to take a few pic's with my RaceYellow Calipers :2tu: :usa:
It's really nice having real brakes. For anyone that's interested, you can PM me for more info. :2tu:
Hey Carl,
It's not about pedal travel with new pads and full fluid, it's about worn pads, extended pistons, reservoir volume, MC fluid displacement volume and MC piston travel. If you haven't read the epic Adelberg and Roe brake battle, you could be headed for big problems. :p
Bugeater
Virginia Beach
Hey Dave got your voicemail, congrats!
As for Dean's point, its well taken - fwiw, I have an ABS master cylinder on my car, and it has brembo 4-piston front and rears. Granted, my piston sizes front and rear are less than the total volume of the SRT's but in my situation the brake pedal travel was not overly affected with worn pads up to the point of required replacement.
I think you will be fine with travel, but you wont know 100% until you burn a set down, or put a set of worn pads on as a test.
When I get an ABS controller and tone rings, I will be buying your brackets!
Kevsmu4
