Windshield Wipers Sword-fight
Discussion in 'RT/10 and GTS Discussions' started by Vpr898, Jun 24, 2018.
What needs replacing?
  1. Driver's side motor
    0 vote(s)
    0.0%
  2. Passenger's side motor
    2 vote(s)
    100.0%
  3. Wiper control module
    0 vote(s)
    0.0%
  4. Car's owner (please no)
    0 vote(s)
    0.0%
  1. Vpr898
    Vpr898 Viper Owner
    23
    Aug 14, 2015
    Rochester, NY
    I have read through this forum, other online resources, and the vehicle's service manual...only to be completely unsure of how to proceed and which part(s) to replace. I have embedded a link below of a video of my particular issue as it unfolds. Any assistance would be appreciated, even if it makes me look stupid. Thank you all
    (1996 GTS Coupe)
  2. KyViper
    KyViper Viper Owner
    36
    Mar 24, 2001
    off to get a Beer
    Try video again with the windshield wetted down. To me looks like 22 year old wiper motors and blades running on a dry windshield. Which by the way may also scratch a tough to find and replace windshield.
    Ky
  3. Vpr898
    Vpr898 Viper Owner
    23
    Aug 14, 2015
    Rochester, NY
    Fair, and I shall. But those are brand new blades, and the very same happens in the wet
  4. AviP
    AviP Viper Owner
    2,272
    Nov 7, 2000
    New Canaan, CT
    Did you remove the wiper arms or just the wiper blades? Because it's obvious that there is some adjustment needed. I have a huge writeup in the service manual on this but it's better to narrow it down if possible.
    Also, do the blades touch each other in the parked position? Here's some wiper arm basics in the parked position:
    - The driver wiper blade is over the passenger wiper blade.
    - The passenger wiper blade at the blade pivot point is 7/8" over the black cowl trim.
    - The driver wiper blade at the blade pivot point is 1-9/16' over the black cowl trim.
    - The passenger wiper blade should not touch the cowl trim while going to the park position.
    - The driver wiper blade should not touch the passenger wiper blade while going to the park position.
    Finally, torque at the wiper arm might be a factor too.
  5. Vpr898
    Vpr898 Viper Owner
    23
    Aug 14, 2015
    Rochester, NY
    I followed that exactly, I have the same manual. Parked blades are properly spaced from the cowl and from each other. And the torque is to spec.
    Anything else you see?
  6. AviP
    AviP Viper Owner
    2,272
    Nov 7, 2000
    New Canaan, CT
    Glad you have the manual. Have you done the 3 tests in the manual for the Wiper Motor, Switch and Wiring?
    Here's my train of thought.
    - The driver motor seems fine on outward stroke and stop.
    - The passenger motor seems to stutter on both the outward stroke and stop.
    - The controller is fine since it is trying to do the best based on its inputs.
    - Assuming the above to be true, it's either a bad power connection or a bad syn signal at the passenger motor.
    Check for connectivity and corrosion all over but specifically at 2 places:
    - terminal 5 (passenger motor) to terminal 19 (controller) for the syn signal
    - terminal 7 (passenger motor) to terminal 5 (controller) for the power signal
    Make sure you have a good battery. Unfortunately, that's all I can deduce at this point. Let us know how it goes.
    ViperJeff likes this.
  7. Vpr898
    Vpr898 Viper Owner
    23
    Aug 14, 2015
    Rochester, NY
    Thanks, Avi
    I have not had the chance to check connections yet, but I did run two back-to-back tests with the windshield wet (as requested). Those videos are below.
  8. AviP
    AviP Viper Owner
    2,272
    Nov 7, 2000
    New Canaan, CT
    The passenger wiper seems to stutter in both videos while the driver wiper barely stutters in the first. I'm still calling out the passenger motor as it definitely stutters in all 3 videos.
  9. Shaggy
    Shaggy Enthusiast Staff Member
    36
    Mar 30, 2017
    Arizona
    You think its the motors that are bad or just need adjusting?
  10. ViperJohn
    ViperJohn VCA Member - Northeast
    3,611
    May 29, 2003
    Maryland
    You may have a bad wiper control module or one of motors is going bad causing them to get out of sync. I know the fronts on Gen 2 are both minivan rear wiper motors from the same model era.
  11. androbud
    androbud Viper Owner
    62
    Apr 16, 2006
    Syracuse, NY
    I had the same issue years ago. If I remember correctly, one side has a positon sensor and when the blades meet your sensor isn't working correctly. I know I was able to Frankenstein a setup back together much cheaper than buying a new unit but it's been so long ago I can't remember how. I think the motor is the same for both sides but the mounting bracket is different. This issue is a pain to deal with and you REALLY need a service manual so that you're going down the right path.
  12. AZTVR
    AZTVR Enthusiast
    2,996
    Aug 28, 2005
    Chandler AZ
    My memory of issues posted on the forum was that if there appears to be a problem with one of the motors, then it is usually caused by a problem in the other one.
  13. Lalmeida617
    Lalmeida617 Enthusiast
    Apr 12, 2018
    Westport, MA
    I am not a viper owner yet however this seams to be a major issue with them. Of the 3 I looked at with under 30k on them 2 have had this issue. I have done a lot of research on this problem. So here goes.
    It is one of these issues.
    Most likely cause is the Passenger side motor. This motor has the brain in it.
    Then the drivers side motor.
    Then the timer which I think is in a false floor under the passenger footwell area.
    The timers usually don’t go bad.
    Tighten the nut holding the arm to the stud. Was it loose don’t go nuts a turn or so?
    Lastly it could be wiring related but these cars don’t see much bad weather but u never know.
    Some have been able to fix there bad motor. I think the magnet that senses the wipers position fall out. (But I am not 100% on this). There is a procedure in the repair manual which explains how to test for which motor is bad. I hope this helps.
    For now remove the passenger wiper arm from the post.
    At least u will be able to get buy with the drivers blade if u get stuck in the rain.
    Could u do me a favor and post a pic of how the wiper motors are mounted in the cowl area. I cannot find a pic of there location anywhere and are they easy to change or a project?
    This has prevented me from buying 2 Vipers a 94 and a sweet 96 Rt10 I am still searching!
    Good luck
  14. Vpr898
    Vpr898 Viper Owner
    23
    Aug 14, 2015
    Rochester, NY
    UPDATE:
    Over the weekend I disassembled the wiper system again and conducted the tests outlined in the service manual to evaluate the motors and the switch, all independently. I did not have and still do not have any suspicion that the wiring is at fault, and as that testing procedure involved leads I had not prepared, I skipped that test.
    The switch tested fine, no faults. I removed the control module and gave it a gross inspection; nothing caught my eye on the board. I also didn't really suspect the control module. I tested the motors individually, connected directly to a power source via test leads as described in the manual. The driver's side motor appeared and sounded robust and responsive, especially when compared to the operation of the passenger side motor. When tested, especially on the high speed terminal, the passenger side motor looked and sounded sluggish and responded poorly.
    Satisfied with my testing results thus far, I have ordered and await the delivery of a replacement OEM passenger side wiper motor. (MOPAR part number: 04643065)
    I don't have a photo handy, but to answer your question. The process of disassembling this area is easy. Expose wiper arm nut both sides, remove nut (13 mm I think) on both arms, remove arms, remove four philips screws securing cowl, remove cowl, remove motor covers, remove three 10 mm bolts each motor, remove motors. Not a difficult project.
    I will update this thread with my results.
Share This Page
