1995 RT/10 Headlight Problem
Patrick Boyle
Massachusetts
I don't usually take my car out at night, so just discovered this problem a few nights ago. When i pull out the headlight switch nothing happens. The foglights switch does not do anything either, but I'm guessing that is because they only work with the headlights on.
Oddly enough the brights do come on when i pull on the stalk. Has this happened to anyone else? Where should I start looking for the problem? Im thinking it could be a fuse, or a problem with the switch, but thought someone might be able to give me some guidance.
Thanks,
Patrick
ViperRed
Bahrain
My car is a 93, and on the 1st pull of the switch, only the side lights and tail lights come on.
Also, in this position, the fog lights do not come on when I press the fog light switch. I have noticed this too.
On the 2nd pull of the switch, the headlights come on. In this mode, I am able to switch on the fog lights too.
By pulling back on the stalk, full beams flash.
What's the issue you're having?
When you say "brights", are you referring to the main lights? Or in Europe, they call them "dip beams"
sloth
