98/02 exhaust manifold pipe size ?
luc
Paso Robles CA
Hi,
need to know the diameter of the exhaust manifold pipe on a 98/02 Viper.
(don't want to remove the exhaust shield on mine to check it).
thanks.
Luc. 00GTS
Tom F&L GoR
Wappingers Falls
An individual cylinder pipe, measured on a straight run section, is 1.610" OD. The collector, just past the mating flange, is 2.50" OD and 2.310" to 2.325" ID.
L
luc
Paso Robles CA
thanks Tom.
Luc.00GTS
( I need to install a dual EGT gauge on a racing viper and the thermocouple probe(s) is retained on the pipe(s) by a clamp.)
SDViper
