Bruce bryan
Apologize for the redundancy up front....
2010 ACR with Bellanger system and hi flow cats....it started throwing CEL code P0031.
2010 ACR
Car has Bellanger LT headers and hi-flow cats
Pulled both exhaust sills
Replaced both sets of 02 sensors on each side (both upstream and downstream)
Repaired/replaced connections from sensors to ecu harness (somewhat melted)
The drivers bank 02 sensor connector was in the worst condition for sure which correlates of course to the P0031 CEL
Changed from the NGK “4 hole” sensors to Denso “slotted” sensors on all
All exhaust components are wrapped with heat insulation
Replaced both ASD 20A fuses (originals looked good)
Car runs great, as new…. only has +/- 7500 miles
Drove it (so far) +/- 65 miles under various conditions
No CELs during driving…BUT UPON RESTARTING EITHER COLD OR HOT I’m still getting the right heater bank low voltage light
I plan on driving some additional miles and hopefully the ECU will adapt…I may re-check the wiring repair on the drivers side upstream connection but I don’t think it’s the problem
I really need to pass emissions testing so It can pass State inspection in Texas.
Any input is welcomed and Thanks in Advance!
2010 ACR
