clutch questions
Bigviper
ENGLAND
burnt out my standard at the weekend doing a 1/4 mile at santa pod :omg:,low down is replace with standard clutch and fly wheel or go after market? i,m running gts 2002 with a 5lb pullie on a roe blower , around 550 bhp :2tu:any surgestions??:dunno:the car had 4000 on it before the blower went on it, and has now done 7000
VIPER BAZ UK
ENGLAND
Is that on the stock Flywheel Mark?????
Need to get this fixed ASAP as its going out in 3 weeks time....
Omaha NE.
Yes the clutch is very heat resistant as far as wear and tear. It is for use with a stock or aluminum flywheel, but if you reuse yours you need check your old flywheel for hot spotting and warping before you install a new clutch or else it will be very short lived.
Madduc
Fremont,MI
I got my clutch set-up from ROE, Centerforce pressure plate and dual-friction disk along with the Fidanza flywheel for my 8lb roe. Running sticky Kumhoe's and no problem at all with the clutch.
RobZilla
Jacksonville, FL USA
I like the chromoly flywheel I got from PartsRack. It's a bit far since your on the other side of the water. Look a few up and consider one as well.
:usa:
