correct torque spec for oil pan
ViperRay
Topeka, KS
10 qt with aluminum gasket. Did some very spirited driving today and noticed a few oil drops on ground afterward. Installed the larger 10 qt pan with baffles, windage tray, ACR filter adapter a couple mos ago on my '97 GTS. Used the aluminum gasket with some high temp silicone sealer. Just routine driving till today. Want to make sure of the torque for oil pan bolts with aluminum gasket. Service manual says 11 N-m for stock pan and gasket. Also don't know if having added a little silicone makes a difference. Thanks.
