Could be coming
TrackAire
Vacaville, California
I've studied this design a bit. It has some merit. Here are my initial thoughts, maybe others have more info to put into this for discussion.
For a high performance driving car, tire pressures are part of handling and being able to "tune" the cars handling....not sure this can be adjusted with this new spoke design.
For vehicles that drive off road through mud, rocks, etc, I'd have concerns that mud or rocks would get stuck inside the spoke area and cause a huge balance problem when the car gets back to road speeds. Same for parking the car outside in a snow/ice storm and having the spokes impacted with ice....can this cause a balance problem?
Tire pressures are also a measure of the load capacity for a tire. On a 3/4 ton truck, most stock tires are rated to carry the full capacity weight-wise at full pressure....usually 80 psi. But what if you're running around with an empty truck, 80 psi is going to ride like a buckboard. Again, not sure if there is a way to adjust the stiffness of the spokes so they can be softened to relieve ride harshness.
I do see these as a plus for construction equipment, farm equipment and over the road vehicles that have constant weight, speeds and conditions.
When the tread wears out, can you have it economically recapped or is there going to be some sort of exchange program??
Should be interesting to see where this product goes and how they engineer around some of the potential issues.
George
v10viperbox
San Diego
George
Spoke with one of the reps at one point maybe not this exact company.
They can tune the inner ring to give a specific response.
They had covers on one set that I was shown for off-road use but I was told that they could form the inner barrel in such a way that once you got up to speed all the mud just gets flinged out.
Tread was replaceable with some form of capture bolt.
v10enomous
NW Jersey
Buy it today on an ATV... I have ATV tires with 15 plugs in them so this is a great advance.
http://www.polaris.com/en-us/atv-qu...311-AE7E-0050569A00BB&wt.mc_ev=email&WT.mc_id
ACRucrazy
Beat me to it! Was just going to post this.
sjanaswamy
