Guys, I am having a issue with my 08 vert. The passenger door is rubbing in the front of the door where it meets a triangular panel. The panel appears to be inboard a small amount at the top and just need to be adjusted outboard. the door appears to be aligned correctly with good spacing everywhere around it. The door has had the paint and some of the door material worn off from 5 years or so of use. It's not too bad and looks pretty easy for any shop to fix. As for adjusting the panel spacing it away from the body shouldn't be too hard. I see two screws in the top of the panel that I can access. I am concerned with how the triangular panel comes out. If there are any body guru's here, I'd appreciate the assistance.
Picture included of generic car and the white circled area is what I am talking about.
Thank you,
Andy
Thank you,
Andy
