Easy Cleaning
Weber
Ocean View
Is there an easy way to clean the rear window and deck (behind the seat) of a Gen3 Viper convertible without going through various contortions?
I have seen products advertised that are kind of like a swiffer sort of wand thing that either already has a microfiber pad on them or you can clip a rag. Basically just makes wiping steeply slanted windshields and stuff like that down. Could work for the rear window maybe, but it's still tough to get back there even with a tool. If you could get someone to hold the top partially open that might be a slightly easier way to vacuum out the little carpet tray, but it pretty much ***** no matter what you do. Just not much room between the roof and the top of the rear waterfall panel.
Weber
Weber
Ocean View
Thanks Mr. President,
I've been holding the top partially open with one hand and working with the other.....was hoping there was an easier way so I'll look into the wand thing.
Here's a quick reference picture of what I was talking about:
Just look up windshield cleaning tool and you can find them all over the place. You can really make one out of a spatula and a rag as well if you really wanted (I've seen it done).
sloth
