Engine block heater
luc
Paso Robles CA
Do Vipers sold in Canada come from the factory with an engine block heater?
Anyone has the part# for it? (Gen 2)
luc 00GTS
KepRght
CA (925)
no chance. :D
the only heater it needs is starting it up. if you have the right mixture of water/coolant and a normal T-Stat 192? degrees you will be fine.
D
DAMN YANKEE
Guest
D
DAMN YANKEE
Guest
All comedy aside...with synthetic oil you should be able to safely crank your VIper at VERY low temps without a hitch.
One could also consider any of these...
Pro Heat OIL PAN HEATER KITS : JC Whitney: Auto Parts & Accessories
Engine oil pan heaters, filter heaters & battery warmers. Designed for cars, diesel engines, more effective than block heaters, magnetic heaters. Suitable for Volkswagen vw beetle, Audi, Land Rover, Ford, Chrysler, GM,
Universal Preheaters [E TIP, Inc.]
ZeroStart Magnet-mount Engine Block Heater : JC Whitney: Auto Parts & Accessories
I have used the magnetic one on my truck for years, works like a charm. I always feel good when the engine cranks up like a summer day. I have a sign I prop on the dash to remind me its there...Figure on a higher electric bill.
RAYSIR
Salem, OR
luc, Really doubt it comes factory or dealer installed. Most don't even know what they are. The block heater fits in the right rear freeze plug 1-2 0'clock position. I would exit the cord to the right A/C drier area. To get one it is for a Ram pickup. NAPA part # 605-1620. Usually only need to have it plugged in 2hrs before you leave and plug in when it is 20 degrees or below. We use a timer in the outside plug in so it comes on and off everyday at the same time. Over the last 4 years my shop has had a Federal Grant to put them on for $25.00 to the customer and City pays the rest. It's a 'reduce emmissions' thing since Anchorage busts emmissions in Dec and Jan with the cold inversions. We put on 2630 heaters last winter in 4 months over 8000 last 4 yrs but the program just ended. LOL. We put in several in V10 trucks but no Vipers. I park my Viper for the winter.:(
RedEnuf93
Lancaster, PA
luc 00GTS
Coming from Finland I know damn well what a engine block heater is...
Never seen one in a Viper though. Do you actually store the Viper outside AND drive it in those temperatures?
I drive mine in 20F, no problem, but I definately dont store it outside.:2tu:
