1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Engine Coolant Temp Sensor
Discussion in 'SRT10 and SRT10 Coupe Discussions' started by q8_viper, Jan 15, 2013.
  1. q8_viper
    q8_viper Enthusiast
    Dec 8, 2012
    Kuwait
    Hello ,
    I get check engine light . I have set this code many time every day . I cleared it with my scan tool and now it's back. This problem come after i install the 160 thermostat . My car 2008 and mods are Mopar ECU , Belanger headers , high flow and Corsa exhaust system . The weather very cold right now .
  2. bluesrt
    bluesrt Enthusiast
    5,011
    Nov 17, 2008
    put the stock stat back in
  3. q8_viper
    q8_viper Enthusiast
    Dec 8, 2012
    Kuwait
    So i do not need to change the Engine Coolant Temp Sensor ???
  4. Allan
    Allan Enthusiast
    2,546
    Mar 7, 2009
    La Junta Colorado 81050
    is it a P0125 or P0128?.........................:eater:
  5. q8_viper
    q8_viper Enthusiast
    Dec 8, 2012
    Kuwait
    It is P0116
  6. q8_viper
    q8_viper Enthusiast
    Dec 8, 2012
    Kuwait
    Any suggestion ? help please ?
  7. Allan
    Allan Enthusiast
    2,546
    Mar 7, 2009
    P0116 is usually the sensor.
  8. ViperGeorge
    ViperGeorge Enthusiast
    2,248
    Nov 9, 2007
    Greenwood Village, CO
    Since the code showed up after you changed the thermostat I'd have to agree with Bluesrt, put the original back in and see if the problem goes away. My guess is the PCM thinks there is something wrong because the engine is not coming up to the temp it thinks it should be at after running for a while. PCM could very well assume that the sensor is bad as a result when in reality the engine is too cold. When I changed the thermostat in my 06 I had Dan Cragin reprogram the PCM. He did something to settings for the fan at a minimum not sure what else he did. Not an option for a Gen IV if that is what you have.
Share This Page
