Fluid Changes
Bill W
Greenville, SC
Most of us don't use our Vipers as daily drivers, putting only 1,000 to 3,000 miles on them each year. Having said that, how often do you change your oil, coolant, clutch fluid, and brake fluid?
Also curious about the transmission/differential fluid.
doctormosfet
Mahopac, NY
I haven't had my Viper as long as others on here, but I change my oil (and filter) each year, right before putting it up for winter storage. I'm planning to do brake/clutch/transmission/coolant over the winter, going into spring, with a general expectation of 2-3 years between flushes. Coolant especially, since glycol (to my understanding) becomes corrosive as it ages. I haven't done the diff fluid yet, but I'll probably add that to the "while I'm at it" list.
efnfast
Canada
oil - once a year at start of season
coolant - every 5 years
transmission/differential - every 10 years
brake/clutch - eventually, if i can remember
Badinternet
Dallas
I just follow the manual on intervals, every 6months for oil or 6K miles, whichever comes sooner. The others are rarer obviously but I don't have the book infront of me.
Hyder124
Ramsey MN
Im glad you mentioned coolant. Ive mentioned this to some other Viper owners at car shows and have gotten odd looks. Ive read that the coolant and the metals in the block don't mix, but is that with todays coolant? or a coolant of the past? Ive only had my Viper about 18 months and I've changed the oil and the coolant. I want to do the brake fluid and rear diff. this winter. Anyone have tips for those?
Old School
North Alabama
I've swapped all my older vehicles with green coolant over to a more modern coolant. I use Zerex G05. It's supposed to last twice as long. Vipers might be easiest on coolant life since there are no dissimilar metals, block, heads and radiator are all aluminum.
If your diff is like a Gen3, it will have 2 drain plugs. The one on the driver's side drains all the gear oil.
doctormosfet
Mahopac, NY
To my understanding, most coolants have propylene glycol as the active ingredient. Pretty much the same stuff used in your closed loop HVAC in your house. Over time, the glycol breaks down and the water/coolant mixture ends up with a higher % water content, which is better for heat transfer but more corrosive. That mucks up copper lines and your local HVAC guy, if he's worth anything, will recommend a HVAC flush every few years. I can't imagine it's any better or different inside an engine block. Better safe than sorry.
I'm pretty similar on the first two. I add makeup oil as necessary.
Because I track my car quite a lot and it gets VERY hot - I do the trans and diff about every 18-24 months. Brakes - I do in Jan or Feb when the humidity is very low and don't need to touch it the rest of the year. Clutch fluid (before I put the remote bleed line on) I would use the turkey baster and change out the reservoir fluid about every other year. Now, I do a complete bleed about 12-18 months since it's so easy.
Shark2th
